Exports all files in document which has names like `mypart [dxf]` or `thing [stl,step]`
to individual files in a export directory. Default prefix: 'export/$project-'
Can be ran both as a macro from the FreeCAD UI and as a script on commandline.
This allows treating the FreeCAD file as a single-source-of-truth,
and to automate the tedious and error-prone task of updating derivative/exported files.
Work-in-process, but thought I'd make it public early
Download from: https://github.com/jonnor/projects/tree ... rt-project
Part of a bigger project in 'continious integration' (like in software) workflows around FreeCAD.
Where this would be one of the steps automatically done when checking in / tagging a new version of a project/part.
One-click project export
Re: One-click project export
interesting! please keep posting about that continuous integration workflow... many more good ideas could come out!
Documented the overall idea of the continious integration system now. Full working document: https://github.com/jonnor/projects/tree ... on-for-cad
Here is an excerpt of the most important.
Continious integration (CI) is a best-pratice in software development. A CI system picks up
very change made to source/project files in a shared revisioning system (like git).
It then runs a bunch of automated tasks, including verification, documentation generation.
If all checks pass, and - publishes the results to an accessible place online (intra/internet).
It helps in keeping quality up because all the tedious (and error-prone) aspects of quality assurance
and publishing are automated.
What would such a workflow look like for CAD?
Particularly one centered on open source digital fabrication?
And overall flow could be like this:
* Check in changes in git, push to something like Github
* A CI service, something like Travis picks up the changes
* Export individual artifacts from the project sources.
3d-models, renders/previews (images/interactive), fabrication data (CNC/laser cutsheets), assembly drawings.
* Generate documentation from sources + other descriptions.
Webpage(s) describing the model/project, including links/embedding exported artifacts.
* Verifies that the outputs are good.
Individual models checks like watertightness, etc.
Checking project-wide constraints like stable 'interfaces' of parts, assemblies fitting together, maximum material or cost budgets.
FEM analysis.
* If checks pass, publishes/deploys the results.
To local website, but also to sharing services like Thingiverse/Youmagine or production services like Shapeways/Ponoko/Sculpteo
Most parts I have pretty concrete idea of how I want to implement initial prototype with (see full doc). But for instance testing/verification of models is an interesting topic that I don't really have any clue about yet. Would love input!
FEM analysis.
Check Geometry tool is usually used on a model to find potential issues. As for assembly i guess ATM there is only 3'rd Party module for that and it does have a tool to check for overlap. If you are thinking in this direction...But for instance testing/verification of models is an interesting topic that I don't really have any clue about yet. Would love input!
I feel that you will probably find areas you would like to support along the way. As i do imagine for example CNC related tasks will need specific support compared to for example designs for building a house.
I try it soon
thank you
thank you
I love free projects
https://www.youtube.com/mauriziospaccialbelli
how is the development going?jonnor wrote:ping
