Get all Shells/Faces/Edges/Vertices at a particular point in 3D space
Using Python, is there a way to look up all objects (shells/faces/edges/vertices) in a body that intersect with a particular point in 3D space?
For example, imagine my body is a cube occupying [0, 1]x[0, 1]x[0, 1]. Given the point (0, 0, 0.5), I'd like to get the Python edge from (0, 0, 0) to (0, 0, 1). Given the point (0, 0.5, 0.5), I'd like to get the face on the YZ-plane in Python.
Re: Get all Shells/Faces/Edges/Vertices at a particular point in 3D space
doc = App.ActiveDocument
box = doc.addObject("Part::Box", "Box")
doc.recompute()
point = App.Vector(5, 0, 5)
distance, points, info = box.Shape.distToShape(Part.Vertex(point))
print(info)
What is the structure of info?
[('Face', 2, (5.0, 5.0), 'Vertex', 0, None)]:
'Face' = subelement
2 = index of subelement (zero-based)
(5.0, 5.0) = (u, v) parameters of the point.
Fantastic. Thank you!
How do I evaluate the subelement at the supplied parameters?
face = box.Shape.Faces[2]
print(face.valueAt(5,5)) #-> Vector (5.0, 0.0, 5.0)
face.Surface.normal(5,5)# normal at location etc.
How do I transform the result of valueAt into a correct 3D point? I'm trying to use it to produce a point cloud of a BREP, but it is giving incorrect results.
valeAt is returning a Vector() and usually a Vector() will suffice to feed many methods that uses "3d Points" like lines and other entities. In other word where you have to use the returned info?
Regards
Carlo D.
- Various other stuffs.
