[Solved]:How is data exchanged between FreeCAD and Workbench
xianyu
Post by xianyu »
At present, I am developing Workbench and can realize some simple functions.
However,I don't know how FreeCAD and Workbench exchange data, the interface between them,or how does FreeCAD recognize user actions in the Workbench?
Is it APP and Gui?Does anyone know, thanks.
OS: Windows 10 Version 2009
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Freecad novice, A Python enthusiast
Re: Question:How is data exchanged between FreeCAD and Workbench
Post by Kunda1 »
Does Workbench_creation help at all ?
xianyu
Post by xianyu »
Thanks for your reply.
My workbench creation learned this Workbench creation → FreeCAD commands →Python command definition ,but I still don't know how they exchange data.
For example, in the Part workbench,i want to add optical properties to a surface of the cube, such as smooth, rough, etc. How does FreeCAD know which surface I have selected?
xianyu
Post by xianyu »
xianyu wrote: Fri Jul 01, 2022 2:12 am For example, in the Part workbench,i want to add optical properties to a surface of the cube, such as smooth, rough, etc. How does FreeCAD know which surface I have selected?
Is using FreeCAD. and FreeCADGui.?
Post by Kunda1 »
@Chris_G can you offer any good explanations/tutorials for @xianyu to follow?
onekk
Post by onekk »
xianyu wrote: Fri Jul 01, 2022 9:56 am
First of all, Please put your FC info using the instruction done in:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
Without them answers could not be correct as some thing change between versions, and sometimes even with "Python version" hat could be different depending on the way FC is compiled and what OS you use.
Without some code is difficult to tell you how things works!
It is difficult to put together a code that is rather complex.
Some rough and not technically correct explanation:
Rough explanation FC is composed by two parts:
1) FreeCAD that is also called an referred as App that is the "modelling engine" part
2) FreeCADGui that is also called Gui that is the "visualization Part" i.e the GUI but not only.
These part are related, and are working together when you use the FreeCAD program.
Roughly the "modelling engine" Part is realted to the "Data" Tab on the ComboView and the "visualization Part" is in the "View Tab".
What you select is managed usually by the Gui part and you could obtain it using:
selection = FreeCADGui.Selection.getSelectionEx()
l_sen = len(selection)
if l_sen != 1:
    msg = f"You have selected <b>{l_sen}</b> shape(s)<br>"
    msg += "You must select only 1 shape <br>"
    print(msg)
else:
    do_something(selection)
selection could be composed by many things, so you have to choose what you want, in the case above using selection[0] will gave you the selected solid as if you select more than 1 solid it usually print an error in the "Report View" (It could depend on some setting in preferences, but usually it will work on stock FC)
Hope it helps
Carlo D.
- Various other stuffs.
xianyu
Post by xianyu »
onekk wrote: Fri Jul 01, 2022 12:04 pm
if l_sen != 1:
    print(msg)
else:
I'm so sorry, I ignored FC information.
Yes, I have read about APP and Gui on wiki.
This code is FreeCAD recognizes the user's selection operation? What if I want to select a face in the cube
I know that when I click on an object, the Python Console will show addSelection and clearSelection.
Does this still apply?
https://wiki.freecadweb.org/Selection_API/de
onekk
Post by onekk »
xianyu wrote: Mon Jul 04, 2022 6:15 am I'm so sorry, I ignored FC information.
once you have the shape you could takecwhat is into the shape.
The page you linked is correct.
Sekection should return even the subshape, try to search for getSelection in the forum and you will probably find some hints on usage
Regards.
Carlo D
