Making the Help system work for TechDraw command groups
Roy_043
Post by Roy_043 »
The TechDraw Workbench has 16 command groups. They occur as dropdowns (or 'flyouts') in the toolbars. For the Help system (Std_WhatsThis) to work properly a Wiki page must exist for each group. To avoid having to create (and maintain and translate) these 16 pages, which would just contain a copied portion of the main TechDraw_Workbench page anyway, I have created them as 'redirects' instead. Each of the 16 redirect pages redirects to a span element on the TechDraw_Workbench page.
To test how this works:
  1. Make sure the Help addon is installed.
  2. If you are using Windows and FreeCAD V0.21 read this: https://forum.freecadweb.org/viewtopic.php?f=3&t=72381
  3. In the preferences (Preferences_Editor#Help) specify the https://wiki.freecad.org/ URL and leave the Language suffix blank.
  4. Call Std_WhatsThis.
  5. Click on a toolbar flyout.
  6. The Help should redirect you to the correct span element on the TechDraw_Workbench page.
As already explained, I think this is a solution that is more efficient. But if anyone has serious objections I can roll it back of course. If there are no objections I will create redirects for the other languages as well.
FBXL5
Re: Making the Help system work for TechDraw command groups
Post by FBXL5 »
Seeing redirects and span elements in action I would say that I like it.
Go for it! 8-)
Edit: All icons I have tried redirected to the right section of the page.
david69
Post by david69 »
it works too for me.
OS: Ubuntu 22.04.1 LTS (LXQt/Lubuntu)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: French/France (fr_FR)
Installed mods:
  * Help.backup1662889774.5125165 1.0.3
  * Help 1.0.3
david69
Post by david69 »
just update the French wiki pages and in parallel I was looking for the translations on Crowdin to synchronize both translation. I can not find the new entrances like "Adjust stacking order of views". I think they are missing but they also can be stucked. @wandererfan do you have an idea?
wandererfan
Post by wandererfan »
david69 wrote: Fri Oct 14, 2022 8:14 am @wandererfan do you have an idea?
I would guess that the translations for new functions have not be been extracted from the source code yet. I think @yorik runs the extract and load to Crowdin on request.
yorik
Founder
Post by yorik »
Doing it right now ;)
