A2+ Shaft Added
devils4ever
A2+ Shaft Added
Post by devils4ever »
I am using A2+ to build a clock and have an issue with a shaft being added by the A2+ workbench. Initially, I added the wheel and it was fine. I updated the model and it grew a shaft. I've tried deleting it and adding it back, but the shaft seems to reappear. See photos.
Assembly view:
Wheel view showing no shaft:
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * A2plus
  * Assembly4
  * fasteners
  * fcgear 1.0.0
devils4ever
Re: A2+ Shaft Added
Installed mods:
* A2plus
* Assembly4
* fasteners
* fcgear 1.0.0
devils4ever
Re: A2+ Shaft Added
I started a new document with A2+ workbench and added the same part. The shaft is still there. Very weird.
Anyone know how to resolve this?
dan-miel
Re: A2+ Shaft Added
Post by dan-miel »
devils4ever wrote: Thu Nov 17, 2022 6:39 pm I started a new document with A2+ workbench and added the same part. The shaft is still there. Very weird.
Can you attach the part file?
Dan
devils4ever
Re: A2+ Shaft Added
Sure.
DeadbeatWheel.FCStd
(304.77 KiB) Downloaded 42 times
dan-miel
Re: A2+ Shaft Added
Post by dan-miel »
The shaft is an endmill that more than likely was made transparent in the part file and became visible in the a2+ file. If you highlight the shaft and hit the spacebar it will toggle between visible and in-visible. You can delete it if you want to. or perhaps keep it invisible.
Dan
devils4ever
Re: A2+ Shaft Added
The endmill is from the Path workbench and is invisible there. If I select the shaft in the A2+ workbench and hit the space bar, the entire part becomes invisible.
dan-miel
Re: A2+ Shaft Added
Post by dan-miel »
devils4ever wrote: Sat Nov 19, 2022 9:57 am The endmill is from the Path workbench and is invisible there. If I select the shaft in the A2+ workbench and hit the space bar, the entire part becomes invisible.
Open the part file and highlight the Endmill in the tree list and hit the space bar. It should then become visible. Delete the shaft in the part file and update it in A2.
Dan
dan-miel
Re: A2+ Shaft Added
Post by dan-miel »
dan-miel wrote: Sat Nov 19, 2022 4:18 pm Open the part file and highlight the Endmill in the tree list and hit the space bar. It should then become visible. Delete the shaft in the part file and update it in A2.
Thanks for the A2+ assembly file. I also had to delete all the other transparent features in the part file before it updated in the assembly file. The transparent features are outlined in green in the picture.
devils4ever
Re: A2+ Shaft Added
Okay. That worked. Thanks!
