Potential Cross-Over Interests between Assembly and Arch workbenches.
I posted a crazy Stairway idea about stairs in the Open Discussion, then it was moved to Draft, Arch & BIM category where only Arch workbench stuff is. That makes some sense, however I think it also has interest to the Assembly Workbench.
A series of Stairway Steps is an Assembly, with Part-Body constraints from one step to the next.
https://forum.freecadweb.org/viewtopic.php?f=23&t=72788
I wonder if there is some simple way of implementing and automating the concepts into Assembly3. It is a very narrow Assembly concept with just one constraint that can define the path of a stairway, almost entirely. Maybe someone has used this method before or maybe it is a dumb idea.
To build a stairway piece by piece in Assembly3 would be a little tedious, but I think it could be highly automated since stairways have to follow rules that predetermine most of the constraint and link parameters.
Assembly3: Stairs
