how to constrain end of one beam to center of another beam
ericg
Post by ericg »
I'm trying to learn A2+ by assembling a simple bed/bench type of frame, consisting of 2 long lengths of 4x2 and 3 short 4x2 spreaders. The 2 end spreaders are easy to constrain to the ends of the long lengths but I cannot seem to constrain the middle spreader to the center of the long beams (I have 1 dof to fix)
Hope that makes sense
Eric
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * A2plus 0.4.56a
Bench_Assembly.FCStd
(23.38 KiB) Downloaded 22 times
dan-miel
Re: how to constrain end of one beam to center of another beam
Post by dan-miel »
ericg wrote: Tue Jul 12, 2022 12:14 pm I cannot seem to constrain the middle spreader to the center of the long beams
Greetings ericg,
Unfortunately, I know of no way to add rectangular parts to the center line of anther rectangular part in A2plus. I normally divide the length of the long beam in two, then minus the width of the center beam. In your case 1960 /2 = 980 – 25 = 955. I use the plane coincident between the end of the long beam and the edge of the center beam, then enter the 955 dimension in the Offset box.
I know this is not the most convenient solution because if you change the length of the bench you need to change the 955 dimension but it is the only one I’ve found. If anyone has a better solution, please post.
Dan Miel
Bench_Assembly with center.FCStd
(23.59 KiB) Downloaded 19 times
Syres
Post by Syres »
dan-miel wrote: Wed Jul 13, 2022 8:24 pm In your case 1960 /2 = 980 – 25 = 955.
Dan Miel
Is TopoNaming stopping the use of expressions, as shown below?
(b_Front_Beam_001_.Shape.Edge10.Length/2) - (b_Side_Beam_001_.Shape.Edge6.Length/2)
I'm aware that if Use experimental topological naming wasn't ticked at time of importing of the objects then it won't work afterwards, so a new file would have to be created and importing to repeated.
ericg
Post by ericg »
Thanks for the replies,
Don't think any of this is going to help as I have several woodwork designs that are not simple edge to edge boxes, one of whic is a router table whre the top overhangs all sides and I really don't want to be fiddling with offsets,
Cheers
Eric
