Assembly3 Not In Current Windows Weekly Builds?
michaelquigley
Post by michaelquigley »
I've noticed that in the current weekly conda builds for Windows, that Assembly3 is no longer present? Is this intentional? I've been running weekly builds with Assembly3 for coming up on a couple of years now.
I genuinely apologize if this has already been answered elsewhere.
Thanks in advance,
Michael
adrianinsaval
Re: Assembly3 Not In Current Windows Weekly Builds?
Post by adrianinsaval »
michaelquigley wrote: Wed Jun 22, 2022 5:46 pm Assembly3 is no longer present? Is this intentional?
Yes, assembly 3 is now available in the addon manager, previously it was included for convenience in those builds when it wasn't available there and had to be manually installed as well as installing a dependency for it, current version of the addon manager should auto install that dependency when you install the workbench.
michaelquigley
Ok... Got it!
Installed through the Addon Manager.
Thank you for the response!
michaelquigley
I've got Assembly3 installed, but every time I try to solve an assembly I just get:
17:24:39  0.312986 <asm3.sys> solver.py(412): no assembly found
I wonder if the SolveSpace bits didn't install properly or something?
michaelquigley
I take it back. Not sure what happened with the test project I made, but I seem to be working again.
Thank you!
