Challenge assembling 2 step Parts.
thomas-neemann
Post by thomas-neemann »
I don't know how I can bring this ball into its position on the plane shown.
I see this as a challenge of the different assembly workbenches or other functions of freecad, additional wbs or macros...
what works, of course, is manual draft move, but that's not sufficient for such a high-precision part
it is also easier to remodel the sphere in the desired position. but then it's no longer a challenge.
start.FCStd
(409.13 KiB) Downloaded 38 times
bambuko
Re: Challenge assembling 2 step Parts.
Post by bambuko »
WPProxy
What is? (and how was it created?)
Screenshot from 2022-04-30 12.43.01.png (25.38 KiB) Viewed 1393 times
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
thomas-neemann
bambuko wrote: Sat Apr 30, 2022 11:44 am WPProxy
this is how i created it. it is the level in which the balls lie. the position of the draft working plane is probably not saved in fcstd
bambuko
Post by bambuko »
Thank you,
no wonder I didn't know what it is... I lead a simple life without draft workbench :mrgreen: :lol:
bambuko
Post by bambuko »
One more question/comment, please.
Clearly assembling a single ball is not the whole story?
We are talking (looking at your second picture in particular) about a number of caged balls,
all of them in a single plane, that should be assembled as a sub-assembly,
with an angle of this plane as a dynamic value depending on the deflection of the joint?
thomas-neemann
bambuko wrote: Sat Apr 30, 2022 12:13 pm
if all the balls can be positioned at the same time with a parametric angle of the joint, that would of course be optimal. but that's probably too much work for here
Can you provide the Inner Race without geometry errors?
bambuko
Post by bambuko »
thomas-neemann wrote: Sat Apr 30, 2022 12:22 pm ...but that's probably too much work for here
It's not a question of "too much work" (and probably it isn't ?)
just that the approach and solution would be different...
thomas-neemann
chrisb wrote: Sat Apr 30, 2022 12:24 pm Can you provide the Inner Race without geometry errors?
here is the source. there are also iges variants contained. it might be more useful
https://grabcad.com/library/rzeppa-joint-2
thomas-neemann
bambuko wrote: Sat Apr 30, 2022 12:32 pm ..
we could make a part A and a part B out of it
