that is better? I reduced it to a minimum
Challenge assembling 2 step Parts.
- thomas-neemann
Re: Challenge assembling 2 step Parts.
no, it is not better
(it's worse)
I am recreating inner race using Part Design workbench - will share when ready...
- thomas-neemann
It's probably a good way, but I can't understand it. how do you create this point?
with you, the balls are not on the sloping level
Alternative (recreated) inner race.
Using Part Design workbench only:
OS: elementary OS 6.1 JAlnir (Pantheon/pantheon)
Version: 2022.407.26244 +4693 (Git) AppImage
Branch: LinkDaily
Hash: 9610830a8fd492b3b3d96f8328507c80f1437cda
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
- thomas-neemann
very kind of you
I need a rest now - it wasn't exactly easy....
but it should make a job of assembling the whole, a lot easier than with step files
- Shalmeneser
- TriLobite.FCStd
- (501.31 KiB) Downloaded 27 times
- Capture d’écran 2022-04-30 192754.jpg (69.66 KiB) Viewed 1251 times
- thomas-neemann
I'm amazed at how quickly experienced freecad users can create such a complex model. Marvelous
- thomas-neemann
Requires registration, and may not offer an error free source object . I would ned to apply boolean operations and these fail on the error containing object. So this is where it ends for me. Using one of the assembly workbenches may lead further.thomas-neemann wrote: ↑Sat Apr 30, 2022 12:50 pm here is the source. there are also iges variants contained. it might be more useful
