A2PLUS joining 3D lines together
Nick1951
Post by Nick1951 »
Hello everybody,
I try to design the crane basement, using A2plus Assembly. Stopped at problem of joining 3 lines together (using point-to-point constraint), unfortunately constrained with other element of whole construction. Could anybody help me with this case ?
Re: A2PLUS joining 3D lines together
Post by Kunda1 »
Mod edit: Moved to Assembly subforum
Please edit the OP and add you full About info (it should also include version of A2plus you are using).
dan-miel wrote: pinged by pinger macro
Nick1951
Post by Nick1951 »
Whole design attached.
A2Plus ver.0.4.48a
FundamentZłożenie.FCStd
(34.66 KiB) Downloaded 31 times
Post by Kunda1 »
Kunda1 wrote: Fri Apr 29, 2022 4:26 pm Please edit the OP and add you full About info.
Still hasn't been done
Nick1951
Post by Nick1951 »
If I were know how to make Datum Plane :
- lying on the line joining free vertex
- and paralel to x-y plane
I would be find the solution soon.
Nick1951
Post by Nick1951 »
I' d like to know how to find coordinates the both Vertex of line 1 and line 2. Then it would be easy to add third point at the same 'z' coordinate as both free vertices (I suppose they should have the same 'z').
I'm not familiar with A2Plus, so this is a mere guess: A2Plus tries to change the Placement of the Sketch and that's not possible, because it is attached.
dan-miel
Post by dan-miel »
Nick1951 wrote: Fri Apr 29, 2022 2:20 pm I try to design the crane basement, using A2plus Assembly.
I haven’t tried to draw parts in A2plus. I normally create/model 3D parts in the Part Design workbench and then import the parts into A2plus. I then use constraints to mate the parts together. I’m not saying you can’t model in A2plus I just saying I have never tried it.
Dan
PS. For the information Kunda1 is asking for go to the help menu > AboutFreeCAD > press “Copy to clipboard”, then paste to the post.
Nick1951
Post by Nick1951 »
OS: Windows 10 (10.0)
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: Polish/Poland (pl_PL)
Nick1951
Post by Nick1951 »
Fortunately I solve the abovemensioned problem in other way (learning is time consuming process ;) )
But have a next pitstop: how to carry a parabola, achieved as a result of cutting the cone by plane to other Sketch (showing of cone face developed view).
