(SOLVED) How can I assemble a valve train?
- thomas-neemann
I am trying to assemble 2 step parts.
with draft move i can't find any possibility via snap without additional auxiliary construction. in assembly 3 i get an error message. I'm probably using it wrong.
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.28765 (Git) AppImage
Branch: (HEAD detached at 795f86c)
Hash: 795f86c18c22260cfc3627bdd5b71504b9dca4ef
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Last edited by thomas-neemann on Sat Apr 30, 2022 5:16 am, edited 2 times in total.
- thomas-neemann
Re: How can I out of the box e.g. assemble a valve train?
after many tries in assembly3 i gave up. here is a suggestion with an auxiliary construction
https://www.youtube.com/watch?v=t8iEqtaFkRc
Edit>Alignment
But, I find it easier to just use Manipulator workbench.
Moved from Help forum.
- thomas-neemann
thank you for your cooperation. I am not familiar with alignment. how do i reach the tangent point and how do i move the part only in the z direction?
TBH, the Edit>Aligment tool IMO could be removed from FreeCAD, it is that unusable by mere mortals.thomas-neemann wrote: ↑Fri Apr 29, 2022 11:55 amthank you for your cooperation. I am not familiar with alignment. how do i reach the tangent point and how do i move the part only in the z direction?
I mention it because it is "out of the box" FreeCAD.
That is why I almost always use Manipulator WB.
- thomas-neemann
Yes, sometimes less is more. the glid in my opinion also for additional macros and wbs. If you want to exchange files with other freecad users or often have to change versions, I find it advantageous out of the box.
That may be the case for some things. But, Manipulator just moves things and leaves nothing that would cause an issue if the file was shared.thomas-neemann wrote: ↑Fri Apr 29, 2022 12:41 pmYes, sometimes less is more. the glid in my opinion also for additional macros and wbs. If you want to exchange files with other freecad users or often have to change versions, I find it advantageous out of the box.
- thomas-neemann
thanks for the information, that's good to know
- thomas-neemann
if the nock doesn't have a circular arc but a spline, i can't get any further in the skecher because it can't tangent to splines. I can't do it with manipulator either. is there any addon (macro wb) with which you can create it on e.g. 1/100 millimeter?
or does it work with the manipulator? (I am not familiar with it)
