Can't rotate body in Assembly
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/New Zealand (en_NZ)
Assembly4
I want to rotate this Drive Pillar clockwise to parallel the Idler Pillar at the back None of the Axis Controls in Attachment has any effect.
What am I misunderstanding?
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Assembly4
- PR-02-Parts.FCStd
- (829.18 KiB) Downloaded 14 times
- PR-02-000.FCStd
- (7.32 KiB) Downloaded 10 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
Re: Can't rotate body in Assembly
Assembly items move by their LCS.
They should shift with Attachment parameters.
Check out the Attachment Parameters for Idler Pillar PR-02-008
Joseph Kimble
Joseph Kimble
Moved from Help forum.
- thomas-neemann
I can't open it correctly. can you upload these two files?
PR-01-Parts.FCStd' does not exist
PR-03-Parts.FCStd' does not exist
ich biete freecad online-support an, als mini-job
VHS Freecad Webseminare Herbst 2022
https://www.vhs-lingen.de/programm/beru ... 011#inhalt
https://www.vhs-lingen.de/programm/beru ... 012#inhalt
Assembly https://1drv.ms/u/s!ArMxdUYEh9fKwCjw0bV ... s?e=mDaukN
Parts https://1drv.ms/u/s!ArMxdUYEh9fKwClJqrk ... f?e=Yavp0v
Joseph Kimble
Joseph Kimble
- thomas-neemann
For some reason the files downloaded onto my machine as *.FCStd1
When I knock off the '1' all is well
Joseph Kimble
Joseph Kimble
- thomas-neemann
I did that too. but these files are probably missing
PR-01-Parts.FCStd
PR-03-Parts.FCStd
