[SOLVED] I keep getting this error when using A2plus
I keep getting this error when using A2plus and I don't know what is causing it. I am still new to freecad, so I'm not sure if I am using the assembly workbench improperly. "Window Slide Assy" is actually a subassembly, part of a larger assembly "General Assembly" (again not sure if that is problematic). This error occurs after I add Window Slide Assy to the General Assembly. Can you tell me what this error means and how to avoid it?
- Window Slide Assy.FCStd
- (38.56 KiB) Downloaded 27 times
- General Assembly.FCStd
- (690.85 KiB) Downloaded 32 times
Reason: Added [Solved] to thread title
Re: I keep getting this error when using A2plus
Moved to Assembly subforum
jlytle.jlytle1801 wrote: ↑Fri Apr 15, 2022 8:07 pm I keep getting this error when using A2plus and I don't know what is causing it. I
I notice that you have the One Button function on. This is a new function and seems to be causing this error. I cannot reproduce this error but try turning the function off and see if the error stops.
Dan
- Mouse Icon.JPG (8.06 KiB) Viewed 1366 times
jlytle:jlytle1801 wrote: ↑Fri Apr 15, 2022 8:07 pm I keep getting this error when using A2plus and I don't know what is causing it.
I was able to duplicate the problem while checking you other problem. I’m putting the fix on github and hopefully it will be updated soon.
Dan
The fix for the mouse has been added to the latest release of A2plus.
Dan
