I created a part in partdesign.
When i import it in A2plus using ''Add a part from an external file to the assembly''
the part is missing the last operation i did on it (multitransform001)
The part is updated and saved before importing in assembly.
I tried closing and reopening.
When i open the part only in part design, the part is complete.
Anyone knows this issue?
Im new to freecad, i was used to Catia and Autodesk inventor !
Capture 1 : In A2plus
Capture 2 : In partdesign
Thks!!
A2plus Object doesnt completly load in A2plus
- Capture2.PNG (214.1 KiB) Viewed 817 times
- Capture1.PNG (212.64 KiB) Viewed 817 times
Re: A2plus Object doesnt completly load in A2plus
Hi and welcome to the forum!
Is Tip correctly set in the body with the MultiTransform? If not, please upload the files.
Hi,pierricoco wrote: ↑Fri Apr 15, 2022 12:28 am I created a part in partdesign.
in order to reproduce the error i have created something similar with 2 multitransform operations, but my test works without that effect.
Please can you post your PartDesign file ?
- part-with-double-multitransform.FCStd
- (70.8 KiB) Downloaded 28 times
- asm-001-multitransform.FCStd
- (26.26 KiB) Downloaded 30 times
KBWBE
latest release: v0.4.56, installable via FreeCAD's addon manager
