Assembly conflict checker
I've put together an assembly with Assembly 4 Workbench, and I would like to check whether there is any conflict, which would hinder putting the assembly together as intended. How should I do that? For example, I would like to know whether the holes and pins are at the right position and their depth/length is appropriate. With other words I would like to know whether the parts in my document have any common volume. I hope my question is clear enough even though I definitively do not know the appropriate technical phrase (probably that's why my search-fu has not resulted in an answer). Thanks!
Re: Assembly conflict checker
Which assembly workbench are you using ? FreeCAD doesn't have a single official one, instead there are 3 different assembly modules available.
Moved from Help forum.
