Does anyone know if A2Plus supports face colors on the parts it imports?
I made a simple test object in Part Design, and set multiple colors on the faces. Then imported it to another doc in A2Plus, and it lost the colors.
Is there a way to keep the colors in A2Plus? If not, do you know if any of the other assembly workbenches can keep colors?
Thanks!
A2Plus: Face Colors
A2Plus: Face Colors
- 1.png (42.59 KiB) Viewed 892 times
- 2.png (40.44 KiB) Viewed 892 times
Re: A2Plus: Face Colors
Based on my tests, it seems that colors are imported to A2plus only with STEP files, not with .FCStd ones.
You could try the other assembly workbenches.
- adrianinsaval
asm3 and asm4 should keep the colors because they use links, A2+ makes a plain copy of the shape so I think it doesn't support colors.
Moved to Assembly forum.
