[Feature] Constraint Diagnostics for troubleshooting A2+ constraints.
I use this program to troubleshoot constraints in A2plus. It contains a table view that can import a list of multiple constraints from an assembly part or from the tree.
Once imported, you can view the constraint or one attachment point at a time, suppress or un-suppress the constraints and solve with A2plus until you find the problem ones.
To find a small, hard-to-find constraint, use the “Find by Label” button. This attaches a label to the constraint leg in the viewer. To find a constraint in the tree, select the constraint and click the “Find in Tree”, then scroll until you see the constraint highlighted in bright yellow.
If the constraint is connected to the wrong surface, you can change that surface to another by using the “Attach to” button.
The other button is for updating edited parts. When you use the A2plus update button, you get a message “Cannot solve” but it doesn’t give much information on how to fix the problem. These problems are normally caused by the name of the attachment objects being changed in the part editing. If the size of a part feature is being changed, then the names are not changed; and it is best to update the part using the A2plus solver.
Otherwise, if new features are being added or subtracted, this program will try to solve the constraint by name; if it can’t, it tries to find the correct feature by matching the size of the new to the old feature. If it is not successful, it shows the table and highlights the non-found surfaces in yellow, at which point you can change the missing surface to the intended surface by using the “Attach to” button.
To add this workbench, unzip the folder from the file and add it to your ‘Mod’ directory. If you have a program directory called ‘A2plusmore’ or ‘Constraint Viewer,’ delete these.
If you try this program and it works or doesn’t work or if you have an idea for improvement, please let me know.
These functions has saved me hours of diagnostic time, I hope someone else finds it useful.
Dan Miel
A list of short help videos.
01 when you first open Constraints. https://youtu.be/9L8u2-xBT1Y
02 How to view constraints associated with a part. https://youtu.be/jA9JBXVcd34
03 Highlighted parts not moved error. https://youtu.be/v5dIPjdV-y8
04 Find small constraint with a label. https://youtu.be/yXG1muuJtHk
05 Update constraints one at a time. https://youtu.be/_JWpEvC0AqQ
06 Move a constraint’s attachment to a new surface. https://youtu.be/XtKRF33v5EU
07 How to view constraints in tree. https://youtu.be/Y1-iExD65fs
08 Modifying parts. [url] https://youtu.be/ng9QSUHW09w [url]
08 Video is about 2 minutes but it show the second button to use when modifying parts.
OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Dan Miel
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- Find constraint with label.JPG (110.97 KiB) Viewed 2655 times
- A2pConstraintDiagnostics Ver0.1.zip
- (949.91 KiB) Downloaded 67 times
Reason: Updated title to just announce feature. If not merged in to A2plus it can be it's own standalone workbench
Re: A new workbench for troubleshooting A2+ constraints.
Cool! Is this code available on github ?
No: I have a github account and am trying to figure how to get it up there and figure out a PR submission. These files are the ones to add the a2plus folder for a PR.
Dan
- add to a2plus for troubleshooting.zip
- (39.83 KiB) Downloaded 59 times
Looks like the master branch is more active than devel
You made the PR against 'devel'. Lets see what uwe says?
Re: [Feature] Constraint Diagnostics for troubleshooting A2+ constraints.
PR has been resubmitted as https://github.com/kbwbe/A2plus/pull/456
Merged in to a2plus, congrats!
Testing this feature is easy. There is a mini tutorial on how to temporarily test
See https://github.com/kbwbe/A2plus/pull/45 ... 1073232577
Bug: Switching to A2plus workbench (while in 'dan' branch) throws No module named 'PySide2.QtUiTools'
CC @dan-miel
Kbwbe is on top of it! Fixed in https://github.com/kbwbe/A2plus/commit/ ... 1a0e88603f
