kemes wrote: ↑Sun Mar 13, 2022 9:34 pm
Especially sorry dan-miel for the time you have put into this.
kemes:
No worries, I have been wanting to do this for a year but always seem busy.
Is there a way to trigger element highlighting when a constraint is clicked in the tree?
I'm not sure what you mean by trigger element highlighting.
uwestoehr wrote: ↑Sun Mar 13, 2022 1:46 pm
select a constraint in the tree view and click the icon
Uwestorhr:
Perhaps I should name this tool a diagnostic tool because with the magnifying glass icon you can only view one mate.
With this tool you can import multiple constraints from a part or tree.
Once imported you can view the constraint or one attachment element at a time, suppress or un-suppress the constraints and solve with A2plus until you find the problem ones.
To find a small, hard-to-find constraint, use the “Find by Label” button. This attaches a label to the constraint leg(element) in the viewer (see picture). To find a constraint in the tree, select the constraint name in the tree and click the ‘Find in tree’ button, then scroll until you see the constraint highlighted in bright yellow (see picture).
If the constraint is connected to the wrong surface or element you can change that element to another by using the “Attach to” button.
The other button is for updating edited parts. After editing a part and using the update button in A2plus, you get a message “Cannot solve” but it doesn’t give much information on how to fix the problem. These problems are normally caused by the name of the attachment element being changed in the part when you edited it. When this program is ran it tries to solve the constraint using the name. If this program cannot solve the constraint, it tries to find the correct element by matching the size. If it is not successful it shows the table and highlights, in the table, the non-found surfaces in yellow at which point you can change the missing surface to the intended surface by using the “Move to” button.
These functions has saved me hours of diagnostic time, I hope someone else finds it useful also.
Dan.
