[A2plus] Highlight the selected constraint
I'm really hoping for the feature where after defining a constraint(s) you could go and click a certain constraint in the tree and the elements involved in the constraint would be highlighted in the 3D view. Currently unless you rename the defined constraints its quite a handful to find the right ones in a large assembly.
Is this something that would interest anyone else?
Re: [A2plus] Highlight the selected constraint
But there is already a way: https://wiki.freecadweb.org/A2plus_Work ... t_Handling
You can also try this add-on, called A2PlusMore, and see if it does what you want. It is a copy if A2Plus that used to allow the selections of constraints similar to SolidWorks but that does not work since A2plus had a major new version. However the 'View Constraints" button still works on my machine. The button looks like a Lantern.
https://forum.freecadweb.org/viewtopic. ... start=1820
It is the message dated July 04, 2021
Dan
How? I could not find the info in the wiki.uwestoehr wrote: ↑Sun Mar 06, 2022 9:51 pm But there is already a way: https://wiki.freecadweb.org/A2plus_Work ... t_Handling
Hi Dan! Thanks for this tip. I'll have to try this. Maybe the functionality behind the lantern button could be implemented into the current A2plus?dan-miel wrote: ↑Sun Mar 06, 2022 11:08 pm You can also try this add-on, called A2PlusMore, and see if it does what you want. It is a copy if A2Plus that used to allow the selections of constraints similar to SolidWorks but that does not work since A2plus had a major new version. However the 'View Constraints" button still works on my machine. The button looks like a Lantern.
Dan
If the program works for you try putting the icon on a custom toolbar, that way you don't need to switch between A2Plus and A2plusmore to find the constraints.
Dan
Why did it not work? Did it start or give an error message?
You can send a private message if you would like.
Dan
OS: Windows 10 Version 2009
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
For some reason on the first try it did not react to any click (probably an user error) --> I assumed that it's not compatible with 19.3. I gave it a second try and it did work. Thank you dan-miel! This is a big help when working with large assemblies.dan-miel wrote: ↑Tue Mar 08, 2022 10:17 pmHere is a 30 second video of what it should look like.
https://youtu.be/UPA0rGkEEBY
If the A2+More -addon is not being developed any more would be interesting to see that this functionality, the Constraint Viewer, would be implemented in the main A2+ -project. I might be able to carry out this myself
