I try to assemble some Part Design Objects together with imported Step Files.
On Part Design Object is a Part with the Body and objects from the fastener workbench. (Heatsets, so I think it is good practice to add them to the Part itself before using it in assembly4 WB). So Structure: (see also screenshot)
- Part1
-- Body
--- some datum objects *1)
-- 4x Fastener
-- other datum objects *2)
- Body2
-- datum objects *2)
- Step-Part1
When assembling, I only can find the datum objects directly in top-level hierarchy (marked with *2) ).
So, how do I access the datum objects of the Body that belongs to Part1?
I also tried to move these datum objects to the part, but this breaks the body.
Strange thing is that I already managed to have some datum objects on Part1 level - but I don't remember how I did this.
Assembly4: How to access LCS (or other datum objects) of bodys in part
Re: Assembly4: How to access LCS (or other datum objects) of bodys in part
Yes, this is foreseen : open the Part document, sélect the datum that you want, and click "import datum". This will create à New datum in the top-level part, at the same location. This datum can then be re-used. It is also parametric, It will follow changes
