Sometimes it is necessary to switch the wireframe in order to see the assembly status
But you need to switch each file one by one
There is no way to switch directly in the main assembly
Switching wireframe state in main assembly has no effect
Is there any other way to do this please?
Why Assembly Using Wireframe has no effect,please help?
- xsuper9988
- asm001.png (102.79 KiB) Viewed 1113 times
- asm002.png (116.09 KiB) Viewed 1113 times
- asm003.png (122.56 KiB) Viewed 1113 times
- Shalmeneser
Re: Why Assembly Using Wireframe has no effect,please help?
Selecting all objects (CTRL) then ... ?
- xsuper9988
sorry i couldn't understand your reply
- Shalmeneser
Don't know if it works : do you try to select everything (with CTRL-key) then do what you want ?
- xsuper9988
Click "Wireframe Mode" directly under "Part Design"Shalmeneser wrote: ↑Tue Feb 22, 2022 8:57 am Don't know if it works : do you try to select everything (with CTRL-key) then do what you want ?
But there is no way to directly change all of them under the assembly project.
Or you show me under the assembly project...
