Trace other part in sketch assembly3
DaAwesomeP
Post by DaAwesomeP »
Hello!
If this is the wrong place to get help with Assembly3, please let me know so that I may move my post.
I have a main part and two imported stepper motors shown below:
I want to trace the mounting holes (the holes in the flanges sticking out) onto a sketch in the part behind them. I tried both the ShapeBinder method and adding an externally-referenced line to the sketch, but it says that I can't because it is in another object/file. These don't need to be (and really shouldn't) be permanently linked to the steppers, so any possible method would work here.
I will eventually use these in Assembly3 to more solidly constrain the steppers to the part (and also physically with screws).
Thanks!
FreeCAD 0.19 w/ Assembly3 (latest download from Assembly3 GitHub releases)
OS: Windows 10 (10.0)
Version: 0.19.21911 +2545 (Git)
Branch: LinkStage3
Hash: 04c80c99eee0f7d2f761bdc7d8b32c077adefdec
Python version: 3.6.8
Qt version: 5.12.1
Re: Trace other part in sketch assembly3
DaAwesomeP wrote: Fri Sep 25, 2020 12:59 am If this is the wrong place to get help with Assembly3, please let me know so that I may move my post.
Moved to Assembly forum.
realthunder
Post by realthunder »
One way of doing it is to use the green SubShapeBinder. You can consult my tutorial here. There are probably easier ways depending on your assembly structure. Maybe you can post your files here so that it will be easier to describe the steps.
Try Assembly3 with my custom build of FreeCAD at here.
Post by Kunda1 »
