First basic implementation
maidenone
Re: First basic implementation
Post by maidenone »
I found that SolidWorks is best, probably because that what i am used to. The userinterface of NX feels a bit dated while ProE is beauteful but a little to smart and minimalistic for my taste.
Here is a Draft of the study, Will continue on it later with more pictures and better/longer explanations of functionality.
https://docs.google.com/file/d/0B_qB0Lk ... sp=sharing
NormandC
Post by NormandC »
maidenone wrote:I found that SolidWorks is best, probably because that what i am used to.
That is certainly the reason. I use Solid Edge and find SolidWorks' GUI a total mess.
Although I use at work an old version of Solid Edge prior to Synchronous Technology.
din743
Post by din743 »
maidenone wrote:I found that SolidWorks is best, probably because that what i am used to. The userinterface of NX feels a bit dated while ProE is beauteful but a little to smart and minimalistic for my taste.
You have one strange Pro-E version :)
I think you mixed up between Pro-E and Autodesk Inventor. Pro-E's GUI is very basic compared to Inventor.
maidenone
Post by maidenone »
Its actually Autodesk inventor Fusion, but some times it calls itself ProE :S, its not a application i have used before.
yorik
Founder
Post by yorik »
In any case that's a very interesting document you made... Thanks!
project4
Post by project4 »
Hi guys,
I've checked out the dev-assembly branch from git, but failed to compile with the following error:
FreeCad/free-cad-code/src/Mod/Assembly/App/opendcm/core/equations.hpp:33:41: fatal error: boost/fusion/include/copy.hpp: No such file or directory
I have boost/fusion/include in /usr/include directory, but there is no copy.hpp file...
Any ideas?
I have boost-dev installed.
Using Ubuntu 11.10
Thanks,
Alex
ickby
Post by ickby »
I checked that: copy was introduced with version 1.48, so you need at least that boost version. Don't know which one is shipped with ubuntu 11.10.
Founder
Post by wmayer »
Ubuntu 11.10 is not longer maintained so you should consider upgrading to the LTS version. There boost 1.48 is used.
project4
Post by project4 »
Thanks for fast reply.
Indeed, I have 1.46 here.
Another good reason to upgrade...
oldestfox
Post by oldestfox »
All of this about building "Assembly" is way beyond my understanding. So... a question.(again) :o
In FreeCAD, is *every* line, arc, circle, point or any other *basic* shape identified and stored in the document file such that "assembly" could refer to it to retrieve info and set constraints? The answer is probably obvious to you folks. I just don't go there.
