1) yes
2) So far I think there will be two. The first one to link to a GeometricalObject (which can be Part,Mesh,Pointcloud,...) and a similar one with the exeption it links to a seperate FreeCAD document (multi-model)
3) Its a kind of group without special product features.
4) Body is a special case from the PartDesign module. And yes it contains a kind of starting geometry (three planes).
Its great you have time to makes some icons, I will start to using them! We can change them in the code if newer ones get maid...
Assembly icon
Re: Assembly icon
Stop whining - start coding!
Re: Assembly icon
It also added a "STP_body" when I imported the step and brep files. Is that a bug?jriegel wrote: 4) Body is a special case from the PartDesign module. And yes it contains a kind of starting geometry (three planes).
Do you want us to start serious testing and bug reporting on your Assembly branch? Would you prefer me to wait until after you put it all in master?
OK.jriegel wrote: Its great you have time to makes some icons, I will start to using them! We can change them in the code if newer ones get maid...
Re: Assembly icon
Hi everyone
viewtopic.php?f=10&t=3501
I have been looking at the links you guys posted regarding Catia, Solid Works etc. and I made some more icons for some of the 3D_Constraints and some "lock to axes" , see here (I have posted regarding some of these in the past but I can't remember if I posted about all of them so I think there are some new ones there as well)
https://sites.google.com/site/austpcpub ... straints_2
here is a zip of those icons above So I thought perhaps I could use that Axes cross or do something with it. I was thinking that there was going to be a global axes set and some sorts of local axes, so anyway here are some ideas. 1) just the Axes Cross, 2) Axes cross with a globe 3) Axes cross with a slightly different globe 4) Axes with a "Part/PartDesign" Box
https://sites.google.com/site/austpcpub ... axes_cross
here is a zip file of the four axes cross icons Are any of these suitable for what you wanted Juergen?
Jim
Quote from another topic herejriegel wrote:Could you do one for a general Axis-Cross? Plane and Axis will be introduced into PartDesign with the Assembly branch..
Jim
