Page 197 of 203
Re: Assembly3 preview
Posted: Thu Jun 02, 2022 9:42 am
by Zolko
jpg87 wrote: ↑Wed Jun 01, 2022 12:04 pm
Zolko wrote: ↑Wed Jun 01, 2022 8:25 am
what happens when you open the file in regular FreeCAD (v0.19 or v0.20) ?
The file opens with errors, then the final result is correct.
A FreeCAD file has 2 parts:
- the geometry at the time of saving, as Brep format
- the creation history, which describe the actions/command leading to the geometry
What this means is that LinkDaily treats OCC the same way as Master, which is good. But the file cannot be reconstructed because Master doesn't recognise some commands/keywords from LinkDaily. Therefore, the file is frozen with the available geometry, and looses its parametric relationships.
chrisb wrote: ↑Fri May 27, 2022 7:14 pm
You must not open a realthunder-file in master (vice versa is ok).
Is this documented ? Are we sure we want to go further down this road ?
Posted: Thu Jun 02, 2022 9:58 am
by chrisb
Zolko wrote: ↑Thu Jun 02, 2022 9:42 am
On opening a master-file in Linkstage3 (LS) the file is transformed to some new format. Changing something to a previous step in a model affects later attachments differently in LS than in master. From that it seems obvious that a recompute in LS can yield different results than doing the same in master.
Posted: Thu Jun 02, 2022 8:53 pm
by adrianinsaval
What makes you think this is what we want?
Posted: Thu Jun 02, 2022 10:11 pm
by Zolko
adrianinsaval wrote: ↑Thu Jun 02, 2022 8:53 pm
well, the fact that the LinkStage3 files are incompatible with Master seems to be taken very casually.
Posted: Thu Jun 02, 2022 10:28 pm
by adrianinsaval
Realthunder took that decision a long time ago, it's his fork so what are we supposed to do? Also, it's an experimental branch, expecting full compatibility is unreasonable, how will he add features if it's supposed to be compatible? Users of the fork should know this.
Posted: Fri Jun 03, 2022 7:15 am
by bambuko
because Master doesn't recognise some commands/keywords from LinkDaily...
...and how is Master supposed to recognise things that only exists in Linkstage3 and do not exist in Master?
As a Linkstage3 user I am perfectly comfortable with (and well aware of) the fact that moving to Linkstage3 is mostly one way thing...
Well not quite black and white
statement below is probably bit more accurate:
There are problems with some Master files when opened in Linkstage3
Some Linkstage3 files work perfectly OK in Master.
Posted: Fri Jun 03, 2022 7:32 am
by jpg87
Thank you for the explanations.
I knew that there was incompatibility in this sense between LinkBranch and Master, but I thought that it was only due to the functions of LinkBranch not yet integrated into Master.
Edit:
I share Bambuko's views.
Posted: Fri Jun 03, 2022 8:22 am
by bambuko
jpg87 wrote: ↑Wed Jun 01, 2022 7:58 am
I'm glad I was able to make the drawing below entirely in PartDesign LinkBranch.
Thank you @realthunder !
anyway....
as your project doesn't utilise Assembly3 and is all about Linkstage3 branch, this post and all the comments on it would probably be better as a separate dedicated thread in Link branch sub-forum? (
https://forum.freecadweb.org/viewforum.php?f=44)
Assembly3 can be used in either Master or LinkStage3 branch and all these comments about compatibility between the two are bound to be confusing to Master branch users who use Assembly3 workbench?
Posted: Sat Jun 04, 2022 9:02 am
by jpg87
bambuko wrote: ↑Fri Jun 03, 2022 8:22 am
It's not false ! Although I intend to continue the project with Assembly 3, but it may be long because I draw little at the moment.
I'm still going to report (in the right place this time) a file size issue compared to @ppemawm's with "official" FC20.
https://forum.freecadweb.org/viewtopic.php?f=24&t=67784 )
Posted: Sat Jun 04, 2022 9:17 am
by bambuko
jpg87 wrote: ↑Sat Jun 04, 2022 9:02 am
... file size issue compared to @ppemawm's with "official" FC20...
Yes, that's very interesting - I am looking forward to your report!
