[ Feature Request ] #8791: Adding ISO keyway tool (like Hole feature)
Piero69
Post by Piero69 »
an useful engineering feature to add in PD is the keyway tool (working like the hole one).
Idea could be:
1) selecting the circular edge (to measure it and offer consequently the correct standard dimensions of keyway BxH)
2) selection the reference face for the position (distance from border)
3) digiting the user's lenght according to standard one
waht do you think?
NewJoker
Re: [ Feature Request/Idea ] : ISO keyway tool (like Hole feature)
Post by NewJoker »
And if it could also include design calculations… But that’s likely wishing for too much.
Can you post a mockup of what you would like to see automated?
Piero69
Post by Piero69 »
1) selecting circular edge for shaft
selecting edge.jpg (171.59 KiB) Viewed 2324 times
2) selecting reference face for keyway
selecting reference face.jpg (171.94 KiB) Viewed 2324 times
4) creating a datum plane
creating plane.jpg (216 KiB) Viewed 2324 times
5) generating constrained sketch
Keyway Sketch.jpg (248.73 KiB) Viewed 2324 times
6) through all pocket
chrisb wrote: Tue Sep 20, 2022 12:15 pm Can you post a mockup of what you would like to see automated?
i imagine a keyway tool that, once run, it:
1) asks you the circolar border (diameter is calculated by 3d model so also the key size by ISO table)
2) asks you a reference face for the keyway
3) asks you the key lenght
now the tool automatically
4) creates a datum plane placed at diameter/2 - keyway depth according to given user's reference
5) generates a sketch with the constrained slot according to input
6) makes a through all pocket
that's some images to make it clear
@NewJoker
@chrisb
Piero69
Post by Piero69 »
@chrisb did you see? what do you think?
Sorry, I had missed this one :oops: .
This could be a sensible extension, especially if it respects/includes some ISO defaults. As I personally didn't need it in the past, I would like to see more voices of users needing it. Then it could be decided if it should be included as a native tool, or as an addon.
Piero69 wrote: Wed Sep 21, 2022 6:08 am 1) asks you the circolar border (diameter is calculated by 3d model so also the key size by ISO table)
There are probably two more parameters needed:
- "Position from face" as it is called in your sketch. This should be measured from the circular border
- a MapPath parameter between 0 and 1, describing where around the cylindrical face you would like to place it. Such MapPath occurs also if you attach something normal to an edge.
It doesn't need the DatumPlane, the sketch should be attached directly to the circular border.
I don't know about the ISO, but the german DIN norm knows different shapes here:
- Form A (DIN 6885), this is what you describe, see e.g. https://de.wikipedia.org/wiki/Passfeder
- DIN 6887, which requires a rectangular hole. It has a nose at one end as shown here at the left bottom: https://de.wikipedia.org/wiki/Keil_(Tec ... Keile1.png
- DIN 6888, which is probably a Woodruff key
Piero69
Post by Piero69 »
@chrisb
thanks so much for you reply and remarks, can i make a poll for see people opinion about that?
We had recently some discussions about polls. It is a difficult matter if they should have a binding character, but it can at least give an indication. However, I would guess that people interested in such a feature would have voiced their opinion here.
Piero69
Post by Piero69 »
chrisb wrote: Wed Oct 26, 2022 8:46 am I don't know about the ISO, but the german DIN norm knows different shapes here:
ISO 773-X is DIN 6885-X (X is the suffix for the form A B and AB)
ISO 3912 is DIN 6888
ISO 774 is DIN 6887
a feature according to these standards is ideal for the mechanical design
