Performance: Subtractive helix & Polar Pattern
Re: Performance: Subtractive helix & Polar Pattern
This is an ADDITIVE HELIX polar pattern, but it also suffers from poor performance on Windows machines.
CPU demand rarely goes other 30% usage on re-calc.
As a side note Realthunder's branch seems to be able to outperform the main-branch regularly driving the
CPU to 100%. No I don't have firm stats.....just observed behaviour.
And sorry, but file is too large to upload.
Setting the number of occurrences to 2 should yield a small enough file. Testers can easily change it back.
Adjusted as suggested above the file still is 1,758 KB ....limit per attachment still exceeded.
Then remains the possibility to upload it to a publicly available file server.
OK File can be downloaded from https://github.com/webmite/FreeCAD-Samples
I am pleasantly surprised that FreeCAD seems to use more than one kernel in 0.21. It goes here up to more than 1100%. Time to recompute for the whole model with 19 occurrences is 78 seconds.
Remark: Changing to 19 occurrences yields the same as your image shows. A full recompute lets the ends at the top go to the inside though.
I have reworked the file to use only a single pipe and no PartDesign helix. I attached the arc at the end directly, whih means that the direction may have to be corrected. This avoids the flipping and is much faster:
For 19 occurrences - I have now a time to recompute of 36.5 seconds.
The size for the full 19 occurrences version is now 1.4MB, I upload it here with 2.
OS: macOS 10.16
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
* FC_SU
* DynamicData 2.46.0
* freecad.gears 1.0.0
* FeedsAndSpeeds 0.5.0
* dxf-library
* fcgear 1.0.0
* fasteners 0.4.54
* sheetmetal 0.2.61
* ExplodedAssembly
* Curves 0.6.8
- a19tooth-LH20deg-Involute-Spline_cb.FCStd
- (826.44 KiB) Downloaded 33 times
The original was created with 0.20.2 (latest 'stable' version available on windows).
It would not render the polar array correctly without including both the helix and the sweep individually.
This was a work-around.
Good to hear of the speed improvement. I will look forward to it.
OS: Windows 10 Version 2009
Version: 0.20.2.29603 (Git)
Branch: (HEAD detached at 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
* AnimationFreeCAD 1.0.0
* Curves 0.6.5
* Nodes 0.1.36
* PieMenu
* sheetmetal
My file works in 0.20 too. It takes 148 sec to recompute. maximum CPU usage is 100%, i.e.0.20 uses only one kernel.
