Performance: Subtractive helix & Polar Pattern
PJtraveler
Post by PJtraveler »
I'm working on knurling a cylinder. It took about 20 minutes with 24 instances to 2 subtractive helixes. The GPU was at 0% or close to it, the cpu was running at 2 % and only 17% of memory was in use. I have a reasonably powerful machine (24 cores) 128 GB mem, 3060 GPU, and lots of disk.
Please could we work on the algo to improve the speed?
Thanks,
jnxd
Re: Performance: Subtractive helix & Polar Pattern
Post by jnxd »
One thing I can think of is regarding parallelization. There's not much work to do, but whatever is is being done sequentially. I expect knurling to have a fair bit of intersections, which may be slowing down each of the steps.
As of now I don't know how well parallism is supported in OCCT itself, so what can be done may very well be limited by that.
Are you in the position to show us the model, or any other example where it takes a long time? It can be iaed for future benchmarks.
prai
Post by prai »
I've faced similar issue with Additive Helix, while trying to create a bolt. Please refer : https://forum.freecadweb.org/viewtopic.php?f=19&t=71382
I am attaching the part file with this post, that presents the problem. To replicate the issue, one may try editing the dimensions in Sketch002 in M6_SQ12_3Tr_12mm.FCStd.
(191.03 KiB) Downloaded 68 times
onekk
Post by onekk »
jnxd wrote: Wed Aug 03, 2022 1:22 am One thing I can think of is regarding parallelization. ...
If parallelization is multithreading, I fear that there is not too much support for it in FC, nor for Graphics accelerations or similar thing.
I remember a recent message of @wmayer about this matter, but now I don't remember the proper place.
Regards
Carlo D.
- Various other stuffs.
user1234
Post by user1234 »
PJtraveler wrote: Tue Aug 02, 2022 11:05 pm Please could we work on the algo to improve the speed?
Except FreeCAD (with OCCT and tbb2), there is literately no CAD out there, even commercial, which supports multicore, except a server for deviate 2D drawings with extra license. That more cores are faster in CAD is a fallacy.
Greetings
user1234
user1234
Post by user1234 »
prai wrote: Thu Aug 25, 2022 2:12 am I am attaching the part file with this post, that presents the problem. To replicate the issue, one may try editing the dimensions in Sketch002 in M6_SQ12_3Tr_12mm.FCStd.
There are touching b-spline surfaces there are twisted with a b-spline result line in the middle. Even i give a good commercial CAD only a 50/50 change that the result is good. Just make a rod and cut the helix thread out.
Greetings
user1234
jnxd
Post by jnxd »
onekk wrote: Sat Aug 27, 2022 4:10 pm
Regards
Carlo D.
Multithreading is one kind of parallelism.
And indeed there is little support for parallelism in FreeCAD. What I was saying was that we can't even add support, or will have great difficulty doing so, if it doesn't already exist in OCCT.
I wouldn't be surprised if there are multiple places wmayer said so.
GeneFC
Post by GeneFC »
I don't pay much attention to speed, and I claim no expertise in multicore strategies.
However, I have noted many times that all cores (4) are blasting away at 100% on some mesh operations in FreeCAD. I would guess that the mesh libraries know something about multicore.
Gene
Knurling with patterns of intersecting helices must be a challenge of every CAD system. In FreeCAD it could help a bit giving the helices a very slightly different depth, 10µ should suffice. Increasing the values of AngularDeflection and Deviation can help a lot.
But the best possibility to work on such a file with reasonable response times is to decrease during development time the number of helix instances to 2 or 3 for each direction.
adrianinsaval
Post by adrianinsaval »
