[Request new function] Slot "Counterbore"?
- xsuper9988
Is it possible to add Slot "Counterbore" in "Part_Design Hole Tool"?
Or have other suggestions?
Thank you very much
Thank you very much
- Slot_Counterbore.FCStd
- (22.94 KiB) Downloaded 52 times
- Slot_Counterbore.png (102.86 KiB) Viewed 1800 times
Re: [Request new function] Ellipse "Counterbore"?
Implementing it might not be particularly difficult, but I don't know how many people would actually use it. Pretty sure there are more niche functionalities that can be added, but this could serve little purpose to most people other than making the tools overly complicated. Do you have any real world examples of it which justify adding this particular functionality as opposed to just making sketches and pockets?xsuper9988 wrote: ↑Thu Jul 14, 2022 3:12 am Is it possible to add Ellipse "Counterbore" in "Part_Design Hole Tool"?
Thank you very much
Question about your picture. The hole is not elliptical, but in a shape called a "slot" in sketcher. Is this called "ellipse counterbore" in some practice or is the drawing for demonstration purposes only?
- Shalmeneser
Hexagonal counterbore should be more useful.
And for generalization, it could work selecting a sketch for the counterbore form.
- xsuper9988
OK
I edited the title and content again
Thank you very much
For short distances, most of them are Hexagonal counterbore
Because most of Hexagonal counterbore is 0.5~1.0mm larger than the screw
Sufficient for short distance error adjustment
PS: as picture Slot_Counterbore_exp1
When "Slot", "Slot Counterbore" are used at short distances
A wide range of fixing tools, or the lock position that needs to be adjusted on the assembly...etc
When locking at long distances (>1.5M)
I might choose to use "Slot"
And "Slot Counterbore" is used for long distance and interference
As picture Slot_Counterbore_exp2
Fixed surface on gantry pillars
When long-distance left and right assembly needs to be aligned
- Slot_Counterbore_exp1.png (396.74 KiB) Viewed 1791 times
- Slot_Counterbore_exp2.png (525.57 KiB) Viewed 1791 times
- xsuper9988
YesShalmeneser wrote: ↑Thu Jul 14, 2022 7:56 am Hexagonal counterbore should be more useful.
Hexagonal counterbore most used
Thank you. The terminology might still be a little off, but "slot bore" might work.xsuper9988 wrote: ↑Thu Jul 14, 2022 9:36 amOK
Thank you very much
Thank you for the explanation. It does sound like something useful, either in PD or in an Assembly workbench. Could you make a feature request on Github (make sure it doesn't already exist first)? When making the request, please add a link to this thread otherwise the issue will be closed.xsuper9988 wrote: ↑Thu Jul 14, 2022 9:36 am For short distances, most of them are Hexagonal counterbore
I haven't dealt with PD holes, so I can't really comment on the implementation. It could be something we have to implement ourselves if OCC doesn't have something for this.
Re: [Request new function] Slot "Counterbore"?
I do not know if this is really a good request, since it is technical absolute false. You can not properly tighten a screw in this way. Way too small contact surface in conjunction with a radial friction is no proper work. When you have to adjust something (long sloth or much bigger hole), then you should use big washers anyway.
Greetings
user1234
Also never saw that in real life (and how to produce without exemptions, which needs rework). Also when how do adjust the hexagon angle direction since the hole definitions is a point on a surface (or similar) and have no radial direction at all. If i define one with a sketch, i would be faster to make the hexagon in the sketch anyway.
Greetings
user1234
- Shalmeneser
The Hole operation is a pattern for each circle/arc in the sketch or in the face.
Yes i konw, but i do not mean this. I mean the hexagon direction, seeShalmeneser wrote: ↑Thu Jul 14, 2022 1:25 pm The Hole operation is a pattern for each circle/arc in the sketch or in the face.
Greetings
user1234
- Shalmeneser
I imagine the sketch plane of the form can use the same plane as the one used for the Hole (same position, same orientation).
