The revolution of a face gives an unxepected result
mwlandolsi
Post by mwlandolsi »
I found this bug, hope tha persons who confirm this answer this topic.
1- create new body (part design WB)
2- create a circle in a new sketch
3- pad this sketch, for example for 20 mm
4- select one of the tow circular faces of the cylinder
5- create a line sketch on that face (which will be used as a revolution axis) the line should not intersect the face of course.
6- select that face and create a revolution around that axis.
When the angular parameter is 360 you get no result or you get just the intersection of the tow create features (pad and revolution)
When you decrease the angular parameter, for example 300 you got a different result.
Screenshot from 2022-06-18 10-29-42.png (212.81 KiB) Viewed 1632 times
when you go back to the extruded cylinder and change the length, (try to use some extreame values) you got different results for the revolution.
Screenshot from 2022-06-18 10-29-48.png (187.54 KiB) Viewed 1632 times
Screenshot from 2022-06-18 10-30-20.png (203.1 KiB) Viewed 1632 times
Screenshot from 2022-06-18 10-30-32.png (165.28 KiB) Viewed 1632 times
Please see this video.
Untitled.webm
(865.98 KiB) Downloaded 39 times
OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 0.20.
Branch: unknown
Hash: 81be38ea8dcec49376b6ab8e08f4a85605639f8d
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
Installed mods:
  * Design456 -1439242656.0.0
  * Silk -1439242656.0.0
  * Curves 0.4.2
  * sheetmetal 0.2.49
  * OpticsWorkbench 1.0.8
  * CurvedShapes 1.0.2
Re: [bug] the revolution of a face gives an unxepected result
Please upload the FreeCAD file.
mwlandolsi
revolution.FCStd
(63.12 KiB) Downloaded 43 times
This seems to be one of the well known coplanar problems coming from the OCC geometric kernel. Everything works as it should for angles <360, here with 300° ...
... and even 359.99 works well:
If I attach a sketch and make a circle with the same diameter as the cylinder, I get - expectedly - the same result. If I increase or decrease the diameter by 0.01mm it works in both cases.
Edit it works even with ±0.001mm difference.
Shalmeneser
Post by Shalmeneser »
I can do the same :
* with just one sketch
* no face support
Draw a construction line in the sketch and use it as axis.
Capture du 2022-06-18 13-48-22.png (40.68 KiB) Viewed 1577 times
Velorution_SHALM.FCStd
(48.39 KiB) Downloaded 37 times
mwlandolsi
Shalmeneser wrote: Sat Jun 18, 2022 11:49 am I can do the same :
* no face support
It is obvious that most cases and design problems have a workflow solution in FreeCAD. I wanted just to discuss this issue before reporting this, which looks related to one of the most remarkable characterizations of FreeCAD (pad and revolute a face and so on...).
Should this be reported on FreeCAD issues tracker ?
mwlandolsi wrote: Sun Jun 19, 2022 7:58 am Should this be reported on FreeCAD issues tracker ?
No, I don't think so. FreeCAD can't do much about this, and I guess that there are already more than one ticket concerning the coplanar issues.
mwlandolsi
* no face support
I tried this method and I got some issue.
But when changing "Deviation" in "Objects Style" from 0,5 to 0,1 I got a result and the pad length is longer. But there are no sim lines for the revolution!
also with short pad there is a problem, the sim lines appeared, but the surface does not.
openBrain
Post by openBrain »
The strange thing is that it fails with Pad first then Revolution, but works with Revolution first then Pad... :?
