could not transform body with pad issued from master sketch
mwlandolsi
Post by mwlandolsi »
Just create a sketch, for example a rectangle.
Create a new body
Select the sketch.
Create a pad into the body.
Now try to translate the body! Impossible !
This happen with 0.20
user1234
Re: could not transform body with pad issued from master sketch
Post by user1234 »
When you use PartDesign, you have to transform the body. All in the body stick on the body and have no placement. In Part, every object have an own placement (two different concepts).
Greetings
user1234
mwlandolsi
Thank you for your answer, but it looks that you did not understand what I mean.
It is so simple, just create a sketch with sketcher, and then create a body, create a shape binder based on that sketch.
Pad the binder. Then transform the body.
Screenshot from 2022-06-02 18-11-52.png (179.65 KiB) Viewed 1856 times
This video shows the case
vokoscreen-2022-06-02_17-59-19.mp4.zip
(778.72 KiB) Downloaded 36 times
Shalmeneser
Post by Shalmeneser »
Binder : Data : Relative=false
user1234
Post by user1234 »
mwlandolsi wrote: Thu Jun 02, 2022 5:19 pm Thank you for your answer, but it looks that you did not understand what I mean.
How should i know what you mean, when you wrote nothing about the shapebinder. Shalmeneser wrote the answer. The shapebinder does not respect the placement per default.
Greetings
user1234
mwlandolsi
Thank you all
user1234 wrote: Thu Jun 02, 2022 5:57 pm How should i know what you mean, when you wrote nothing about the shapebinder.
Sorry about that.
Is there a way to set the "relative" property by default to false.
salutations
user1234
Post by user1234 »
mwlandolsi wrote: Thu Jun 02, 2022 6:37 pm Is there a way to set the "relative" property by default to false.
No, as far as i know. But depends how many you want to refer, it is no good idea to use too much of them, else you get a mess.
Greetings
user1234
mwlandolsi wrote: Thu Jun 02, 2022 1:31 pm Just create a sketch, for example a rectangle.
Create a new body
Select the sketch.
Is there a good reason for this workflow? Normally you have the sketches inside of the body; no ShapeBinder needed then.
adrianinsaval
Post by adrianinsaval »
I think that's the just minimum example of something he stumbled upon while using a master sketch. See the resulting request: https://forum.freecadweb.org/viewtopic. ... 38#p599538
mwlandolsi
chrisb wrote: Thu Jun 02, 2022 9:43 pm
Create a new body
Select the sketch.
This is not a workflow, this is a reporting of a case where an operation looked strange for me. Because I used it in other versions of FreeCAD and found it functional.
chrisb wrote: Thu Jun 02, 2022 9:43 pm Normally you have the sketches inside the body; no ShapeBinder needed then.
This is very useful when playing with master sketch (case of transforming 2D plans to 3d for example), especially mold plans and plastic parts design. In this case, we have to create a master sketch and then the stacked parts are coming one by one. When you have to create another dimension, just modify the master sketch.
