Can "Sheet Metal" and "Part Design" be modified to use each other?
- xsuper9988
Like this "Make Forming" cannot use "Linear Pattern"
Here's an example from SolidWorks
https://youtu.be/VZvHL_8BaVM?t=530
- SheetMetal_MakeForming.FCStd
- (71.15 KiB) Downloaded 31 times
- SheetMetal_MakeForming.png (118.73 KiB) Viewed 1707 times
- xsuper9988
Re: Can "Sheet Metal" and "Part Design" be modified to use each other?
Roy sorry I read it three times in detail
I can't see from this documentation about methods like "LinearPattern","PolarPattern"...
Or is there a sample file somewhere else that I can refer to?
To get a pattern of embossed shapes the default approach is to create a sketch with circles. See SheetMetal_MakeForming_Sketch.FCStd.
But instead of a sketch you can also use a Draft Array of circles. The Draft Workbench has several array types (notably: Draft_OrthoArray, Draft_PolarArray and Draft_CircularArray). See SheetMetal_MakeForming_Draft_Array.FCStd.
To use the array, but also to use Body001, you need to rely on PartDesign_SubShapeBinders (or PartDesign_ShapeBinders). Using these objects directly in Body leads to "out of scope" errors
- SheetMetal_MakeForming_Sketch.FCStd
- (55.26 KiB) Downloaded 30 times
- SheetMetal_MakeForming_Draft_Array.FCStd
- (67.03 KiB) Downloaded 33 times
- xsuper9988
Just couldn't find how to put the sketch in itRoy_043 wrote: ↑Wed Jun 01, 2022 12:27 pm To get a pattern of embossed shapes the default approach is to create a sketch with circles. See SheetMetal_MakeForming_Sketch.FCStd.
I have found it
ok, i'll test it again
- SheetMetal_MakeForming1.png (143.84 KiB) Viewed 1511 times
- xsuper9988
original:
To muliply and pattern the embossed feature a sketch containing circles and arcs can be added to the WallForming object's property DataSketch. This pattern sketch must be coplanar with the face to be embossed.
I think it should be modified like this:
To muliply and pattern the embossed feature a sketch containing circles and arcs can be added to the WallForming from object's property Data(object's property Data "Parameters1">"sketch"). This pattern sketch must be coplanar with the face to be embossed.
And add a picture as a description
Like "SheetMetal_MakeForming2.png"
But I see no mention of "Draft" in the documentation
How did you know the "Draft" feature would work too?
- SheetMetal_MakeForming2.png (125.88 KiB) Viewed 1500 times
I disagree. The information about the location of the property is given. You just need to read the rest of the page. And the fact that you need to click the "..." button is very much a standard procedure that should be explained on a different page.
- xsuper9988
You're right
But at least he has to put an example of "Multiply_and_Pattern"
Because I watched it three times before and felt that there is no this function...XD
- xsuper9988
