issue with GUI on part and part design
david69
Post by david69 »
Launch FreeCAD with the setup in a language different from English.
choose Part wb
note that the top shorcut corresponding to Measure is not translate
move to Part Design wb, you got the translation
back to Part wb, you got the right translation now.
that appears with
OS: Ubuntu 18.04.6 LTS (LXDE/Lubuntu)
Version: 0.20.
Branch: unknown
Hash: 30f8015e7111a192db55ab66b9c8a5b02d935ef0
Python 3.6.9, Qt 5.9.5, Coin 4.0.0a, OCC 7.5.2
Locale: French/France (fr_FR)
I report here this issue on Part wb because I don't where else I must do it.
Re: issue with GUI on part and part design
Post by Kunda1 »
david69 wrote: Mon May 30, 2022 4:21 pm I report here this issue on Part wb because I don't where else I must do it.
https://github.com/FreeCAD/FreeCAD-translations
david69
Post by david69 »
is there a confirmation?
the translation is well present, it is more a behavior of Freecad which can hide something.
if you invite me to open a bug, I don't want to open an account on Github.
Post by Kunda1 »
david69 wrote: Tue May 31, 2022 8:14 am if you invite me to open a bug, I don't want to open an account on Github.
That's fair. But that's where we're organizing the task of fixing translations
I can't confirm ATM
david69 wrote: Mon May 30, 2022 4:21 pm Launch FreeCAD with the setup in a language different from English.
choose Part wb
@kaktus do you mind testing this?
kaktus
Post by kaktus »
:mrgreen:
I will of course look into it and let you know. ;)
I have to say right now that David has found a lot of problems in the GUI related to the lack of translations.
We'll report them all together, but I'd like this list to get shorter quickly, because there are plenty of open issues at the moment.
Post by Kunda1 »
@kaktus thank you very much for all your hard work!
kaktus
Post by kaktus »
choose Part wb
Fault confirmed. :o
  1. I started FreeCAD.
  2. Loaded the Part workbench.
  3. The Measure menu label was not translated.
  4. I did whatever (opened the saved project), then the translated label was loaded.
a very intriguing anomaly. :roll:
https://vimeo.com/715594923
@david69 will report this on GitHub in the appropriate branch. :idea:
kaktus
Post by kaktus »
kaktus
Post by kaktus »
@Kunda1
I'd like to remind you of something:
https://forum.freecadweb.org/viewtopic. ... 66#p591466
:P
openBrain
Post by openBrain »
Can confirm the issue. The TS files seem OK...
