Sweep orientation problem in Freecad 0.20
mwlandolsi
Post by mwlandolsi »
When creating sweep feature in part design WB it gives a bud result. Orientation mode could not be changed.
Screenshot from 2022-05-23 15-19-12.png (65.96 KiB) Viewed 868 times
The sweep created in Part WB with the same sketche of th PartDesign WB
In PART WB it is ok, In PartDesign WB the section sketch is not well oriented.
OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 0.20.
Branch: unknown
Hash: 469c36e3ccd58fb254e731d4f1ed96f8268f8507
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
Locale: English/United States (en_US) [ OS: English/United States (en_US) ]
Installed mods:
  * Design456 -942436320.0.0
  * Silk -942436320.0.0
  * Curves 0.4.2
  * sheetmetal 0.2.49
  * OpticsWorkbench 1.0.8
  * CurvedShapes 1.0.2
Shalmeneser
Re: Sweep orientation problem in Freecad 0.20
Post by Shalmeneser »
Corner transition : Right corner
(I don't give file because you don't give file :mrgreen: )
Capture d’écran 2022-05-23 164913.jpg (43.4 KiB) Viewed 856 times
adrianinsaval
Post by adrianinsaval »
file? sweep has a property to control how the profile orientation changes, that might be what makes it different
mwlandolsi
Ok thanks for the answer. It is solved.
