Open the attachment and recompute. The pattern (also on mirrors) will not performed correctly (pattern add). Note there is already a bug fixed, which set always the occurrences to 3, i do not mean this bug).
Interestingly, if you change the Overlap property to Overlap mode the second instance works but the third (and following if set to a higher number) doesn't. My example is based on the minimal one posted by chrisb but the same happens with the other
user1234 wrote: ↑Tue Mar 15, 2022 5:15 pm
Where is this fixed?
When you mean the bug with the 3 occurrences? Here is the link to the bug + bugfixes (i am a little bit in a hurry, if you need something tested, i can a test it, but not asap).
user1234 wrote: ↑Thu Mar 24, 2022 3:56 pm
