Interesting. Just reverting that one commit however gives some very bad result I wonder if this is the only culprit then...user1234 wrote: ↑Fri Mar 25, 2022 6:07 amYes, exactly. I checked out one commit before.
git commit 89b8e81d5c3b11572a0288720d0b4145d2ec2a7e
0.20 bug/regression Array Pattern issue #6641
Re: 0.20 bug/regression Array Pattern
My latest (or last) project: B-spline Construction Project.
I can confirm the bug happens with 7.5.3. Can we try going backwards: trying the branch with 7.4.0?
I also got a similar error, but i only forgot to recompile FreeCAD with the atm installed version.
I think also this issue #6584 regression have the same source, arrays and a little bit refining. I will try some tests .....
Greetings
user1234
I am atm on 7.4.0. But i do not think that this is an issue.
But funny story: i had some issue while recompiling with the fresh master today. So i made a make clean and the result looks different then the days before. The fillet works now with the pattern (the segments are still here).
Greetings
user1234
So is this now working with 7.4.0 or newer version?user1234 wrote: ↑Sat Mar 26, 2022 7:00 pm I am atm on 7.4.0. But i do not think that this is an issue.But funny story: i had some issue while recompiling with the fresh master today. So i made a make clean and the result looks different then the days before. The fillet works now with the pattern (the segments are still here).
That explains why the rib itself is not there. I just rebased if you want to test.
I know, it ws just a remark, that my note before was invalid.
Generally now i know a little bit more. The issue seems the PartDesign Sweep. When i remade the model with Part, i never get the issue, all setting throuht. But when i make i clone ony of the sweep and remade the rest in Part, the issue raises. On OCCT7.4. and 7.6.1.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.28440 (Git)
Hash: 63636c8082e44bc66f9af70c221fbff5dcd46f5e
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, OCC 7.4.0
Locale: C/Default (C)
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, OCC 7.6.1
Greetings
user1234
The issue is still within Transform. The problem is that with changing to CompSolids, some of the fuse/cut shapes are still Compounds, which OCC treats as "more complicated" (since a compound can contain loose faces etc. but I suppose CompSolids cannot). So this addition is causing an issue.
I figured that out a couple hours ago but I'm still figuring how to solve this.
As far as i know, this is true, as long the geometry is not invalid.
Just saying, when i transform the PartDesign Sweep per hand, it also not work. In contrast when i transform a Part Sweep, it works. But this is just my observation i made.
Greeetings
user1234
