Visibility issues with PD Pipes
jnxd
Post by jnxd »
Steps to reproduce:
  1. With the attached file start additive pipe with SketchBase for profile.
  2. Set SketchPath as path.
  3. In section transformation select "Multisection" and add Sketch001 and Sketch002.
After the sweep is made, Sketch001 and Sketch002 are still visible. Further, after undoing, or deleting the sweep, SketchBase becomes visible again, but SketchPath does not.
I don't know if keeping the sections is intended behavior, but the second visibility issue is definitely a bug.
[EDIT] Version details:
OS: Ubuntu 20.04.3 LTS (MATE/mate)
Version: 0.20.26316 (Git)
Build type: Unknown
Branch: (HEAD detached at donovaly/PD-loft-visibility-fix)
Hash: fc608c12acc27451960f00f3cb6f91da0b07df76
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
sweepbug.FCStd
(10.28 KiB) Downloaded 50 times
My latest (or last) project: B-spline Construction Project.
Re: Visibility issues with PD Pipes
Does this occur in master as well (no opportunity to test myself now).
jnxd
Post by jnxd »
chrisb wrote: Mon Nov 08, 2021 8:58 am Does this occur in master as well (no opportunity to test myself now).
Yes. The branch I posted was just one commit ahead, and that commit only changed loft.
jonasb
Post by jonasb »
This sounds similar to this discussion here: https://forum.freecadweb.org/viewtopic.php?f=10&t=63531
I can confirm the issues. It was the same in 0.19.
uwestoehr
Post by uwestoehr »
jnxd wrote: Mon Nov 08, 2021 2:10 am After the sweep is made, Sketch001 and Sketch002 are still visible.
Yes, in the code only the spine and base are made invisible. I agree that all should consistently become invisible since this is also the case for e.g. lofts and who needs to have them visible can do so.
jnxd wrote: Mon Nov 08, 2021 2:10 am Further, after undoing, or deleting the sweep, SketchBase becomes visible again, but SketchPath does not.
I cannot reproduce this. Here the sketch visibility is kept as it is, SketchBase stays invisible:
uwestoehr
Post by uwestoehr »
Here is a PR that should fix the visibility issue: https://github.com/FreeCAD/FreeCAD/pull/5158
Now the profile is treated like the path. I also changed it so that the sections are hidden on closing the pipe.
When deleting the visibility of underlying objects is kept untouched.
With this PR the visibility is now also consistent to lofts.
chennes
Post by chennes »
PR 5163 (the replacement for 5158) is now merged. Note that it does not address the Undo issue -- if you haven't already, could someone please post a tracker ticket for that?
Chris Hennes
Pioneer Library System
uwestoehr
Post by uwestoehr »
chennes wrote: Thu Nov 11, 2021 4:49 am PR 5163 (the replacement for 5158) is now merged. Note that it does not address the Undo issue -- if you haven't already, could someone please post a tracker ticket for that?
@wmayer kindly already fixed it: git commit fb9a3eecff182a9
