A partial pocket that doesn't go all the way through is successful, but when the depth is increased, FC hangs.
See attached model. The last sketch is the pocket operation that fails ( try pocket depth of 15mm) .
OS: Windows 10 (10.0)
Version: 0.19.23756 (Git)
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Pocket operation hangs in Windows
- Fuji Plate 5-straps.FCStd
- (40.6 KiB) Downloaded 66 times
Re: Pocket operation hangs in Windows
I believe that making the slot edge coincident with the external geometry is causing a failure in the OCC routines. Move the slots a tiny bit away from the exiting recess and they will work.
I have seen this a lot recently, after seeing it only rarely in the past. I expect there has been some change in OCC that is more sensitive to coincidence problems.
Gene
Gene
I can work around it by giving a dimension, and not using Through All, or Symmetric . I was reporting the issue with hopes of getting it fixed.
Thanks,
Thanks,
As I pointed out in your topic about fillets this issue of coincidence is very well known and comes up frequently on the forum. Unfortunately the problem appears to stem completely from the OCC kernel.PJtraveler wrote: ↑Sun Feb 07, 2021 7:38 pm I was reporting the issue with hopes of getting it fixed.
Gene
I've been looking into these hangs you are reporting: we do sometime have custom patches to OCC, so if these issues all turned out to be related then it might make sense to do so again. I think I've got a lead on the first of them, I'll keep poking at it as time allows.
I just tested this using OpenCascade 7.5.0 and it actually works fine, so you might consider updating your libpack and recompiling. The bonus is that if you do that, I can post a patched TKShHealing.dll with my fix from your other bug, and it should drop right in.
