Automatically update postprocessing objects when using calculix
din743
Post by din743 »
As mentioned by NewJoker in the past (https://forum.freecadweb.org/viewtopic. ... 60#p618560), the postprocessing objects are currently not updated automatically when using Calculix. Are there plans to change this?
When I used the FEM module for the first time I expected the postprocessing to update automatically like everything else in FreeCAD when you press calculate. I also didn't find this mentioned in the wiki, so I had the search a bit for the problem when I noticed the postprocessing was not updated. It is also tiresome to have to recreate the postprocessing every time something changes. So I think it will be more user friendly if the postprocessing is updated automatically.
NewJoker
Re: Automatically update postprocessing objects when using calculix
Post by NewJoker »
Here’s another discussion about this topic: https://forum.freecadweb.org/viewtopic.php?f=18&t=60974
NewJoker
Post by NewJoker »
Fortunately, it’s not the case anymore: viewtopic.php?t=77149
