Phase transition modelling
rhub
Post by rhub »
Hi all,
I am a quite new user of FreeCAD and I am trying to model phase transition using a temperature dependent specific heat as specified on the CalculiX website (https://www.feacluster.com/CalculiX/ccx ... de172.html) but cannot find a way to do so.
Does anyone know about such feature in FreeCAD?
Thanks
Romain
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
Re: Phase transition modelling
Hi and welcome to the forum!
I moved the post to the FEM section. It is probably sensible to update to 0.20 or 0.21 so that helping comments match your version of FreeCAD.
NewJoker
Post by NewJoker »
rhub wrote: Thu Aug 11, 2022 9:39 am Does anyone know about such feature in FreeCAD?
FreeCAD doesn't support temperature-dependent material properties so you will have to edit the input file manually.
Jee-Bee
Post by Jee-Bee »
Isn't that a part of non linear materials? i kind of would expect that...
NewJoker
Post by NewJoker »
Jee-Bee wrote: Thu Aug 11, 2022 11:59 am Isn't that a part of non linear materials? i kind of would expect that...
No, FEM MaterialMechanicalNonlinear is just for plasticity and there's no equivalent for thermal properties.
rhub
Post by rhub »
NewJoker wrote: Thu Aug 11, 2022 11:53 am FreeCAD doesn't support temperature-dependent material properties so you will have to edit the input file manually.
Thanks for your answer
So I should provide some sort of csv type file including temperature ans specific heat values which would replace the specific heat value inside the .inp file, is that right?
NewJoker
Post by NewJoker »
rhub wrote: Thu Aug 11, 2022 12:51 pm So I should provide some sort of csv type file including temperature ans specific heat values which would replace the specific heat value inside the .inp file, is that right?
It's not necessary. Just define it like this:
*Specific heat
value1, temperature1
value2, temperature2
value3, temperature3
rhub
Post by rhub »
NewJoker wrote: Thu Aug 11, 2022 1:02 pm It's not necessary. Just define it like this:
*Specific heat
Thank you, I just tried this out and it worked.
