Properies Card for Ponderosa Pine?
flyingcadet
Post by flyingcadet »
I'm trying to estimate the load capacity of my shed wall, I would like to add an i-beam for a chain hoist on a trolley.
My shed is framed with #2 Pine or Ponderosa Pine. I tried to write my own card, but it collapses under its own weight.
Any help would be appreciated.
FreeCAD Details:
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * Assembly4 0.12.3
  * CurvedShapes 1.0.4
  * Curves 0.5.3
  * DynamicData 2.46.0
  * FEM_FrontISTR 0.1.0
The source of my values: https://www.fpl.fs.fed.us/documnts/fplg ... 3/ch04.pdf
The results of my bad file.
Wood_Num2Pine_(Ponderosa).FCMat.txt
(770 Bytes) Downloaded 15 times
NewJoker
Re: Properies Card for Ponderosa Pine?
Post by NewJoker »
Can you share the .FCStd file or at least values that you obtained from the simulation ? Deformed shape plot is not enough since it can be scaled. Numbers are what actually matters in FEM.
flyingcadet
Here are the files as requested. I included one with all settings using the "GenericWood" material that comes with FreeCAD and one that's based on the material card in my original post. I had to delete the results to get them under size limits individually.
Appreciatively,
flyingcadet
shed_cad_v2_WoodGeneric.FCStd
(698.04 KiB) Downloaded 16 times
shed_cad_v2_BadMaterial.FCStd
(698.2 KiB) Downloaded 15 times
NewJoker
Post by NewJoker »
The density is wrong - it's defined as 400 kg/cm^3 instead of 400 kg/m^3. This causes the gravitational load and thus also the results to be exactly a million times larger than they should be. You have to be very carefult with units in FEM.
flyingcadet
haha, that's what I get for setting the properties in the middle of the night.
Thank you for the help!
Appreciatively,
Flyingcadet
