Run several simulations ? FEM Freecad
Toutanfil
Post by Toutanfil »
Is it possible to run several simulations one after the other?
With different loads' values or directions ...
It would allow me to run all simulations during the night to process results the following day.
I don't find anything about that online.
OS: Windows 10 Version 2004
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: French/Belgium (fr_BE)
Installed mods:
* A2plus 0.4.56a
* Assembly3 0.11.3
* Assembly4 0.11.12
* fasteners 0.3.40
* Manipulator 1.4.9
* MOOC 2022.4.21
NewJoker
Re: Run several simulations ? FEM Freecad
Post by NewJoker »
It would be easiest to export the .inp file, copy it multiple times and modify each copy - change keywords so that a different load case is evaluated. Then submit these files using CalculiX executable outside of FreeCAD. You can create a batch file with commands submitting these multiple jobs.
Toutanfil
Post by Toutanfil »
Thanks you NewJoker
I will try it.
bernd
Post by bernd »
By python this is very easy to archive in FreeCAD.
In FreeCAD by python:
- set up all your analysis by python or load a saved FreeCAD analysis.
- run the analysis
- save file with results
- clear results
- change parameter
- run analysis
bernd
Post by bernd »
FEM_Tutorial_Python this may help in this regard ...
