Thank you and sorry for posting in the wrong forum. I did see this one and think I just need help and it's not contributing to the FEM development...unless it's a bug
OK so I have re-run everything with the view of packaging up to share and now my 100 bar displacement magnitude is 0.91mm (previously 0.34mm)
Newjoker: Will do I just would expect to see the most displacement located at the source of the pressure and consistently increase along with pressure.
I will share once I've re-run my pressure points but in the meantime is there some sort of polluting cache that needs to be flushed and isn't? I suppose it could be my work flow which is:
Change pressure
Change heat source temp C
Run Solver
View CCX
Repeat
Previously I use to delete the CCX with every solver run as paranoid it didn't refresh properly (unfounded on my part)
