Principal Stress Plots
HarryvL
Re: Principal Stress Plots
Post by HarryvL »
NewJoker wrote: Mon Jun 13, 2022 9:54 am
HarryvL wrote: Mon Jun 13, 2022 9:42 am Do you know what parts to change in both files?
Yes, I compared your files with original ones using Compare plug-in in Notepad++. I made the changes and sent two PRs. Hopefully, they will be accepted.
Are you sure you captured all the changes? See above exchange.
uwestoehr
Post by uwestoehr »
HarryvL wrote: Mon Jun 13, 2022 3:18 pm That's not right then. See my above file and below:
OK, can you please just make a PR by yourself? Since you have GitHub account this should be doable for you n few minutes.
NewJoker
Post by NewJoker »
HarryvL wrote: Mon Jun 13, 2022 3:20 pm Are you sure you captured all the changes? See above exchange.
I removed the lines crossed out in red. The ones marked in blue were already there. It should be fine.
uwestoehr
Post by uwestoehr »
NewJoker wrote: Mon Jun 13, 2022 4:01 pm I removed the lines crossed out in red. The ones marked in blue were already there. It should be fine.
OK, but now I am confused. Just please make a PR ready to be merged.
In the current PR i only see a removal.
So again, why does it harm to have the stresses there? We are few hours before a release and I don't have time to dive in that deep. If the stresses don't harm there, I would keep them.
HarryvL
Post by HarryvL »
It should be fine like this. The fact that they were first declared a vector and after that a scalar meant that it didn’t work. As long as they are declared a vector and the scalar part is removed we are good to go.
NewJoker
Post by NewJoker »
uwestoehr wrote: Mon Jun 13, 2022 4:07 pm OK, but now I am confused. Just please make a PR ready to be merged.
I'm still almost 100% sure that the current PR is correct. What I meant in the previous reply is that I only removed the 3 lines with resFCScalProp because I didn't have to redefine them as vectors above - their equivalents with resFCVecProp were already there in the original file. Notepad shows me all the differences, it would find any other changes that I missed.
And HarryvL confirmed that it was supposed to be done this way.
HarryvL
Post by HarryvL »
They were declared twice. That doesn’t work. Now it is fine.
uwestoehr
Post by uwestoehr »
OK, I merged the 2 PRs. Please checkout if the issue is now fixed for you in master.
HarryvL
Re: [fixed] Principal Stress Plots
Post by HarryvL »
Thanks, I will
uwestoehr
Post by uwestoehr »
uwestoehr wrote: Mon Jun 13, 2022 5:53 pm OK, I merged the 2 PRs. Please checkout if the issue is now fixed for you in master.
Sh..t! I broke master by merging it. Can you please send me a fix for the failing test:
https://gitlab.com/freecad/FreeCAD-CI/-/jobs/2584056477
