[fixed] ResultShow dialog: translating "Peeq"
chennes
Post by chennes »
Right now the "ResultShow.ui" dialog has a string in it labelled "Peeq" (e.g. the equivalent plastic strain). That string is currently marked for translation -- is that correct? If so, are translators expected to also yield a short acronym, or can they spell out the term?
Chris Hennes
Pioneer Library System
Re: ResultShow dialog: translating "Peeq"
Post by Kunda1 »
@NewJoker any idea?
Jee-Bee
Post by Jee-Bee »
But peeq is also output version for the *EL File.
So we should be carefull that the reference to the functions are not translated...
https://www.feacluster.com/CalculiX/ccx ... mentoutput
https://www.feacluster.com/CalculiX/ccx ... tml#elfile
NewJoker
Post by NewJoker »
Kunda1 wrote: Thu Jun 02, 2022 6:34 pm @NewJoker any idea?
We don’t translate it in practice and just talk about PEEQ. Only in some research papers we translate it but then the full name must be used (equivalent plastic strain is directly translated) because abbreviating it in Polish doesn’t make sense. So I would leave it as PEEQ (upper case recommended) since full name is too long to be used in FreeCAD.
chennes
Post by chennes »
Perfect, thanks -- I'll make that adjustment.
Chris Hennes
david69
Post by david69 »
after scratching my head and spent time on the net (it's not my field), in French, they also use that. I guess Chennes you are dealing with Crowdin. thank you.
