Help to show the gradient bar
uwestoehr
Re: Help to show the gradient bar
Post by uwestoehr »
johnwang wrote: Mon Jun 06, 2022 11:31 am Version: 0.20.28717 (Git)
This version is too old. The bug was fixed later. Please upgrade to our beta version and try again:
https://github.com/FreeCAD/FreeCAD/rele ... /0.20beta1
johnwang
Post by johnwang »
uwestoehr wrote: Mon Jun 06, 2022 2:01 pm
Downloaded the new one. Still no scale bar.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
Founder
Post by wmayer »
johnwang wrote: Mon Jun 06, 2022 11:31 am Utilities/Open FEM examples/Solvers/Calculix/Box Analysis Frequency
Is this all what you do? If yes, then a color bar isn't shown because there is no pipeline object created.
After opening the example you still have to perform:
  1. Activate the Analysis object
  2. Double click SolverCalculix and execute the simulation
  3. Select one of the four result objects and run Post pipeline from result
  4. Now you should see a color bar
johnwang
Post by johnwang »
wmayer wrote: Thu Jun 09, 2022 5:59 am [*]Select one of the four result objects and run Post pipeline from result
[*]Now you should see a color bar
I double clicked one to open the show result, then choose displacement x.
No scale bar here.
uwestoehr
Post by uwestoehr »
johnwang wrote: Thu Jun 09, 2022 8:28 am I double clicked one to open the show result, then choose displacement x.
No scale bar here.
I don't understand. Can you please provide a screenshot?
You only need to create a pipeline. When the pipeline is visible you have a scale bar. Here is how it looks directly after I created a pipeline:
johnwang
Post by johnwang »
uwestoehr wrote: Thu Jun 09, 2022 10:02 am you only need to create a pipeline. When the pipeline is visible you have a scale bar. Here is how it looks directly after I created a pipeline:
No need to create ResultPipeline.
Double click your ccx_results to get into Show result.
I only use Show result for ccx. I think I have scale bar a few years ago.
I use pipeline only fox VTK result generated by Elmer and SU2.
Founder
Post by wmayer »
Can you upload your example file, please?
johnwang
Post by johnwang »
wmayer wrote: Thu Jun 09, 2022 11:17 am Can you upload your example file, please?
Founder
Post by wmayer »
johnwang wrote: Thu Jun 09, 2022 11:20 am
That's not what I meant. I wanted to have the file you get when running this command and performing the additional step to create the pipeline object.
uwestoehr
Post by uwestoehr »
johnwang wrote: Thu Jun 09, 2022 10:50 am No need to create ResultPipeline.
A scale bar is only available for pipelines, not for CCX results.
(In my opinion the CCX results are quite useless, because where in your mesh do you have what value? There is no access to this info but this is what one usually needs.)
