Gmsh unknown error
PeterII
Re: Gmesh unknown error
Post by PeterII »
I now made the wire model, and I fused it. Then I created cross section, and I meshed it. Assigned material and tried to compute it. However to no avail. I always get the same error: *ERROR in gen3dfrom1d: element 1 is a linear beam element with circular cross section
Please use quadratic elements for beams with circular cross section
Does someone know what am I doing wrong?
Sticks_mesh.FCStd
(120.2 KiB) Downloaded 23 times
Kind regards,
Peter
Jee-Bee
Post by Jee-Bee »
Sorry I want to try it but somhow GMSH is not part of the default FC anymore...
What i would do now is export the brep and check if you are able to create a mesh inside GMSH self. And if it workout well you can import that one. or compare what the differences are in settings.
To be honest i don't like the GMSH functions inside FC. For everything you need an separated function and most of the time Netgen is create a better mesh(at least for 3D)...
NewJoker
Post by NewJoker »
Jee-Bee wrote: Tue Aug 02, 2022 8:06 am Sorry I want to try it but somhow GMSH is not part of the default FC anymore...
Which version of FreeCAD do you use ? Gmsh should still be included.
Jee-Bee wrote: Tue Aug 02, 2022 8:06 am To be honest i don't like the GMSH functions inside FC. For everything you need an separated function and most of the time Netgen is create a better mesh(at least for 3D)...
Yeah, most meshing issues in FreeCAD happen with Gmsh. However, it's good to have two meshers to choose from and Netgen has some limitations. Most importantly, it doesn't support beam and shell elements in FreeCAD - it can only generate tetrahedrons and Gmsh is needed for other types of elements.
PeterII
Post by PeterII »
I am using:
OS: Windows 10 Version 2009
Version: 0.20.27422 (Git)
Hash: d938733eaf2c2ce7cb18d1cbb56147185c473530
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Slovenian/Slovenia (sl_SI)
So Jee-Bee you think issue is with mesh? Why is that since I get mesh is done correctly status?
Do you think it is possible to do the mesh in meshlab, and then import it?
Kind regards,
Peter
NewJoker
Post by NewJoker »
PeterII wrote: Tue Aug 02, 2022 5:33 am Please use quadratic elements for beams with circular cross section.
Try doing what the error message says - change the element order to 2nd. You may get other errors then but at least this one will be gone.
PeterII
Post by PeterII »
it helped =)
now the error says: *ERROR in gen3delem: first thickness. Any ideas?
Kind regards,
Peter
Jee-Bee
Post by Jee-Bee »
NewJoker wrote: Tue Aug 02, 2022 8:36 am Which version of FreeCAD do you use ? Gmsh should still be included.
OS: macOS 10.15
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
  * A2plus 0.4.56
  * fasteners 0.3.41
  * Assembly4 0.11.12
PeterII wrote: Tue Aug 02, 2022 9:20 am So Jee-Bee you think issue is with mesh? Why is that since I get mesh is done correctly status?
No i didn't say that. I sayed that if i don't get it to work i try in GMSH self. If it able to mesh there i should be able to do it too in FC.
I don't know meshlab so can't help with that
bernd
Re: Gmsh unknown error
Post by bernd »
I edited the title since the name is Gmsh
NewJoker
Post by NewJoker »
PeterII wrote: Tue Aug 02, 2022 9:20 am Do you think it is possible to do the mesh in meshlab, and then import it?
MeshLab is not meant for finite element mesh generation but for operations on triangle meshes, like those contained in the STL files: https://en.wikipedia.org/wiki/Triangle_mesh
FreeCAD's Mesh Design module serves a similar purpose.
bernd
Post by bernd »
Netgen is included if FreeCAD is compiled with Netgen. Gmsh binary is a separate programm. On Windows FreeCAD this binary is included. Genarally on OSX and Linux this binary has to be installed separately and the path might be set in FEM prefs.
