Rigid body constraint
jnxd
Re: Rigid body constraint
Post by jnxd »
bernd wrote: Wed Nov 02, 2022 9:30 pm cool ... the python method to create the object and the unit test for the new object is missing ... See git commit 27f50ad13188faff changes in files
- src/Mod/Fem/femtest/app/test_object.py
- src/Mod/Fem/ObjectsFem.py (but for a C++ object the code is different, look at the file)
Sorry for the late reply. And thanks, I didn't really account for tests, an specifically didn't know of these. My thought was to make tests after a few iterations of the rigid body constraint.
EDIT: I see that I had already made the changes in src/Mod/Fem/ObjectsFem.py, and these were same as those for Fixed constraint. Am I missing something?
My latest (or last) project: B-spline Construction Project.
bernd
Post by bernd »
jnxd wrote: Sat Nov 05, 2022 10:58 am
I just wanted to give the information. Use the FreeCAD-CI whenever you like.
jnxd
Post by jnxd »
bernd wrote: Sat Nov 05, 2022 11:10 am I just wanted to give the information. Use the FreeCAD-CI whenever you like.
Oops. I just edited the previous comment, maybe shortly before you replied. Could you check if my changes to ObjectFem.py are correct?
bernd
Post by bernd »
https://github.com/AjinkyaDahale/FreeCA ... d25a8f4b21
it seams right to me. I missed this somehow. Sorry for the noise in this regard.
bernd
jnxd
Post by jnxd »
bernd wrote: Sat Nov 05, 2022 11:31 am https://github.com/AjinkyaDahale/FreeCA ... d25a8f4b21
bernd
OK, thanks for this. The tests are failing, but not in the location where I added them. Something about a count being off by one. Could you take a look?
bernd
Post by bernd »
Seams you have found it yourself. Am i right. There is no error anymore on FreeCAD-CI.
jnxd
Post by jnxd »
bernd wrote: Sun Nov 06, 2022 7:47 am Seams you have found it yourself. Am i right. There is no error anymore on FreeCAD-CI.
More like you actually already helped out by commenting in Github. Thanks for that.
bernd
Post by bernd »
jnxd wrote: Mon Nov 07, 2022 6:58 am
Ahh that one, :geek:
bernd
Post by bernd »
What I normally do If I create a new object is to create a example as well. Since I do start with object and writer and at last do the gui I need some python to create the object anyway. Some more python and the example is ready. See for example this git commit 94c0522c38
bernd
Post by bernd »
To make all your writer code safe you could add the just added example to the unit test as well. See for example git commit 4fcf01991a92
