What is the output of the button to show the version of Gmsh? You must at least use Gmsh 4.8.HarryvL wrote: ↑Tue Jun 14, 2022 7:45 am I keep getting the following error from GMSH:Code: Select all
Unknown number option 'Mesh.MeshSizeFromCurvature
Implemented Gmsh Mesh Property "MeshSizeFromCurvature"
Re: Implemented Gmsh Mesh Property "MeshSizeFromCurvature"
GMSH produces a mesh, but I can't change any of the options and it gives the MeshSizefromCurvature warning. GMSH version button returns "File not Found" ... but a mesh is produced.
It’s 4.4.1. Great. Thanks.
I installed 4.10.3 and don't get the MeshSizeFromCurvature error anymore. However, the mesh size parameters have no effect and get reset to 0 upon completion. I also get the following FC error in the report view:
TypeError: Can't call meta function because I have no idea how to handle Base::Quantity
OK. Please attach a simple test file here and give a step by step instruction how to reproduce. I'll try to fix this.
Any file will do. For example Box Analysis Static from FEM Examples. Attached for convenience.
Step by step instruction. Activate FEM workbench. Select the box in the tree. Press GMSH icon. Enter a maximum element size (different from 0). Press button to get GMSH going. GMSH completes successfully, but element size is reset to 0.
PS: upon entering GMSH dialog I also get this weird error message in the console. It must be a dialog issue. Not a GMSH issue.
In your file there are 2 meshes, one of it is outside the FEM container.
Deleting both meshes and creating a new one everything works fine. Here my mesh settings:
Here the result:
Here my FreeCAD file:
Thanks Uwe, but unfortunately it doesn't work for me. Even when I use your file and delete the meshes, I still only get one mesh density, irrespective of the settings. When I use your file, the maximum size keeps resetting to 1mm.
By the way, I keep getting the mystery error whenever the dialogue opens or when I enter values to it. I can't trace this error back to a location in the source.
